The Evolve 75 is a wireless headset with superior active noise-cancellation and integrated busylight to enhance your productivity. Dual connectivity to two Bluetooth devices allows you to take calls and listen to music from the same headset, giving you extra freedom to move 30m away from your smartphone and/or PC.
 - Jabra Evolve 75 SE MS Stereo - headset
- Product Type
 - Headset - Bluetooth - wireless - USB
- Recommended Use
 - Portable electronics, computer - communication
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wireless
- Wireless Technology
 - Bluetooth
- Bluetooth Version
 - Bluetooth 4.2
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
- Max Input Power
 - 30 mW
- Active Noise Canceling
- Microphone
 - Boom
- Microphone Operation Mode
 - Uni-directional
- Microphone Noise Cancelling
- Microphones Included
 - 3
- Controls
 - Mute, volume, answer/end, busylight, on/off, ANC on/off, status indicator
- Software Certification
 - Certified for Microsoft Teams
 - 2-year warranty
- Designed For
 - LINK 380a MS
- Product Type
 - 15.5 cm
 - 6.45 cm
 - 18.45 cm
 - 177 g
- Headband Material
 - Foam, silicone
- Earpad Material
 - Leatherette
- Recommended Use
- Max Operating Distance
 - 30 m
Audio Output
 - On-ear
 - Wireless
 - Bluetooth
- Bluetooth Audio Codec
 - SBC
- Bluetooth Version
 - Bluetooth 4.2
- Bluetooth Profiles
 - Advanced Audio Distribution Profile (A2DP), Hands-Free Profile (HFP), Headset Profile (HSP), Audio Gateway Hands-Free Profile (AGHFP)
- Sound Output Mode
 - Stereo
- Active Noise Cancelling Technology
 - Hybrid ANC
 - 20 - 20000 Hz
- Max Input Power
 - 30 mW
- Sensitivity
 - 117 dB
- Simultaneously Connectable Devices Qty
 - 2
 - Busy light, SafeTone technology, Jabra Direct, Jabra Xpress
Microphone
 - Boom
- Form Factor
 - Headset microphone
 - Uni-directional
 - 3
- Sensitivity
 - -17 dBFS/Pa
 - 100 - 10000 Hz
- Signal-to-Noise Ratio
 - 17 dB
- Noise Cancelling
- Audio Input Details
 - Uni-directional - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
 - Headset (4 PIN USB Type A)
- Included Accessories
 - Jabra Link 370 USB Adapter, protective case
- Cable Details
 - USB cable - detachable
 - FCC-ID, KCC, NCC, RCM, SRRC, TELEC, IC
- Battery
 - Headset battery rechargeable
- Run Time (Up To)
 - 18 hour(s)
- Run Time Details
 - Continuous talk: up to 18 hours , Continuous playback: up to 17 hours
- Standby Time
 - 15 days
- Recharge Time
 - 2 hour(s)
 - Limited warranty - 2 years
- Shipping Width
 - 18.1 cm
- Shipping Depth
 - 21 cm
- Shipping Height
 - 5.3 cm
- Designed For
 - Jabra LINK 380a MS
