The Evolve 75 is a wireless headset with superior active noise-cancellation and integrated busylight to enhance your productivity. Dual connectivity to two Bluetooth devices allows you to take calls and listen to music from the same headset, giving you extra freedom to move 30m away from your smartphone and/or PC.
World-class speakers and HD Voice
HD Voice combined with world-class speakers deliver outstanding audio with crystal-clear clarity for your calls and music, whether you need to collaborate or concentrate during your day. -
Superior ANC and integrated busylight
Block out noise and stay focused in the open office with superior ANC and an integrated busylight that acts as a 'do not disturb' sign to reduce interruptions and enhance productivity. -
Dual Bluetooth connectivity
Dual Bluetooth connectivity with two devices at the same time for calls and music. Flexibility to move up to 30 m away from your connected device. -
Comfortable design for all-day use
Intuitive headset with leatherette ear cushions and on-the-ear design enable all-day use with superior comfort for the open office environment. -
Enjoy battery life all day long
Built-in rechargeable battery for up to 18 hours of talk time and an optional stand for easy charging and docking.
- Jabra Evolve 75 SE MS Stereo - headset - with charging stand
- Product Type
- Headset - Bluetooth - wireless - USB
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
- Max Input Power
- 30 mW
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Microphone Noise Cancelling
- Microphones Included
- 3
- Controls
- Mute, volume, status indicator, on/off, answer/end, ANC on/off, busylight
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Bundled with
- Charging stand
- Designed For
- LINK 380a MS
- Product Type
- 15.5 cm
- 6.45 cm
- 18.45 cm
- 177 g
- Headband Material
- Foam, silicone
- Earpad Material
- Leatherette
- Recommended Use
- Max Operating Distance
- 30 m
- Bundled with
- Charging stand
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP)
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Hybrid ANC
- 20 - 20000 Hz
- Max Input Power
- 30 mW
- Sensitivity
- 117 dB
- Simultaneously Connectable Devices Qty
- 2
- Busy light, SafeTone technology, Jabra Direct, Jabra Xpress
Microphone
- Boom
- Form Factor
- Headset microphone
- Uni-directional
- 3
- Sensitivity
- -17 dBFS/Pa
- 100 - 10000 Hz
- Signal-to-Noise Ratio
- 17 dB
- Noise Cancelling
- Audio Input Details
- Uni-directional - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
- Included Accessories
- Protective case, charging stand, Jabra Link 370 USB Adapter
- Cable Details
- USB cable - detachable
- IC, KCC, TELEC, SRRC, NCC, RCM, FCC-ID
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 18 hour(s)
- Run Time Details
- Continuous talk: up to 18 hours , Continuous playback: up to 17 hours
- Standby Time
- 15 days
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
- Shipping Width
- 18.1 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 5.3 cm
- Designed For
- Jabra LINK 380a MS
Jabra Link 380c MS USB-C Bluetooth Adapter | In Stock | £62.40 |
