Jabra Evolve 75 SE Link380a MS Stereo with Stand
Quicklinx: H66MWS00 Mfr#: 7599-842-199
Recommended Use: Portable electronics, Computer
Connectivity: Wireless
Earcover : Binaural
£215.45 ex VAT
£258.54 inc VAT
The Evolve 75 is a wireless headset with superior active noise-cancellation and integrated busylight to enhance your productivity. Dual connectivity to two Bluetooth devices allows you to take calls and listen to music from the same headset, giving you extra freedom to move 30m away from your smartphone and/or PC.
  • World-class speakers and HD Voice
    HD Voice combined with world-class speakers deliver outstanding audio with crystal-clear clarity for your calls and music, whether you need to collaborate or concentrate during your day.
  • Superior ANC and integrated busylight
    Block out noise and stay focused in the open office with superior ANC and an integrated busylight that acts as a 'do not disturb' sign to reduce interruptions and enhance productivity.
  • Dual Bluetooth connectivity
    Dual Bluetooth connectivity with two devices at the same time for calls and music. Flexibility to move up to 30 m away from your connected device.
  • Comfortable design for all-day use
    Intuitive headset with leatherette ear cushions and on-the-ear design enable all-day use with superior comfort for the open office environment.
  • Enjoy battery life all day long
    Built-in rechargeable battery for up to 18 hours of talk time and an optional stand for easy charging and docking.
Jabra Evolve 75 SE MS Stereo - headset - with charging stand
Headset - Bluetooth - wireless - USB
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
Max Input Power
30 mW
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
Uni-directional
Microphone Noise Cancelling
Microphones Included
3
Controls
Mute, volume, answer/end, busylight, on/off, ANC on/off, status indicator
Software Certification
Certified for Microsoft Teams
Bundled with
Charging stand
LINK 380a MS
15.5 cm
6.45 cm
18.45 cm
177 g
Headband Material
Foam, silicone
Earpad Material
Leatherette
Recommended Use
Max Operating Distance
30 m
Bundled with
Charging stand
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Hands-Free Profile (HFP), Headset Profile (HSP), Audio Gateway Hands-Free Profile (AGHFP)
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Hybrid ANC
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Sensitivity
117 dB
Simultaneously Connectable Devices Qty
2
Busy light, SafeTone technology, Jabra Direct, Jabra Xpress
Microphone
Boom
Headset microphone
Uni-directional
3
Sensitivity
-17 dBFS/Pa
Frequency Response
100 - 10000 Hz
Signal-to-Noise Ratio
17 dB
Noise Cancelling
Audio Input Details
Uni-directional - 100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Jabra Link 370 USB Adapter, protective case, charging stand
Cable Details
USB cable - detachable
FCC-ID, KCC, NCC, RCM, SRRC, TELEC, IC
Headset battery rechargeable
Run Time (Up To)
18 hour(s)
Run Time Details
Continuous talk: up to 18 hours , Continuous playback: up to 17 hours
Standby Time
15 days
Recharge Time
2 hour(s)
Shipping Width
18.1 cm
Shipping Depth
21 cm
Shipping Height
5.3 cm
Jabra LINK 380a MS
Recommended Use: Computer
Earcover : Binaural
Brand: Jabra
