Jabra Evolve 65 Duo UC USB Headset
Quicklinx: 9TC3WS00 Mfr#: 6599-829-409
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
Earcover : Binaural
£111.18 ex VAT
£133.41 inc VAT
The Jabra Evolve 65 MS stereo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
Microsoft Lync optimized. Wireless Bluetooth technology gives you up to 30 meters / 100 feet of hands-free connectivity to PC, smartphone and tablet. Up to 10 hours battery life eliminates battery concerns. Simply tap to connect devices with NFC. Dual connectivity enables you to connect your headset to your PC and one other Bluetooth device at the same time, so you can take the call on your preferred phone device. Busy light signals user availability. The microphone boom arm can be integrated into the headband when not on a call. Microphone mute on boom arm. Built for style and comfort with leatherette ear cushions. Soft pouch included.
CHARGE AND STORE
The Evolve 65 now comes with an optional charging stand, providing easy and convenient charging and storage at your desk. The Evolve 65 headset can also be charged without the stand, via the USB cord provided in the box, connected to your PC.
ULTIMATE NOISE CANCELLATION
State-of-the-art noise-cancelling microphone eliminates background noise. You and your conversation partner won't struggle to hear each other.
LONG WIRELESS RANGE
Walk up to 30 meters (100 feet) away from your desk while on a call. You're free to roam around the office to grab a coffee, find documents and multitask. Near Field Communication (NFC) allows you to simply tap your compatible smart device and Jabra Evolve 65 together, and you will be ready to talk or stream music instantly.
INTEGRATED BUSY LIGHT
The Jabra Busy light helps you to cope with the challenges of an open office environment and let people clearly know that you are on the phone. The indicator turns red when you are on a call and keeps you from being interrupted.
  • Made for voice and music
  • Passive noise cancellation
  • Easy call management
  • Busy light
  • Discreet boom arm
  • Up to 30 meters wireless range
  • Up to 10 hours talktime
  • Tap-to-connect
  • Always connected
    Dual Bluetooth connectivity to two devices at the same time for calls and music. Flexibility to move up to 30 m away from your connected device.
  • All-day comfort
    Leather-feel ear cushions and a lightweight, on-the-ear design for all-day use.
Jabra Evolve 65 UC stereo - headset
Headset - Bluetooth - wireless - NFC - USB
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Sound Effects
PureSound
Audio Specifications
Frequency Response 20 - 20000 Hz
Max Input Power
10 mW
Microphone
Boom
Controls
Volume, mute button, answer/end
5.86 cm
15.55 cm
17.05 cm
111 g
Earpad Material
Leatherette
Recommended Use
Max Operating Distance
30 m
Headphones
On-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP)
Sound Output Mode
Stereo
Sound Effects
PureSound
Frequency Response
20 - 20000 Hz
Max Input Power
10 mW
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Simultaneously Connectable Devices Qty
2
Busy light
Microphone
Boom
Headset microphone
Audio Input Details
Uni-directional
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
USB cable - detachable
Carrying pouch, Jabra Link 370 USB Adapter
Plug and Play, IC, FCC, KCC, TELEC, SRRC, NCC, RCM
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Standby Time
360 hours
Recharge Time
2 hour(s)
Shipping Width
18.1 cm
Shipping Depth
21 cm
Shipping Height
5.3 cm
Shipping Weight
171.1 g
9TC3 Jabra USB-A to USB-C Adapter In Stock £7.92
Recommended Use: Portable electronics
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 100 - 150
