Made for voice and music
Truly made for both voice and music with world-class microphone and speakers so you are free to choose if you want to be in your own concentration tone or actively participate in voice-based collaboration. -
Passive noise cancellation
Passive noise cancellation gives you protection from high frequency noise such as human voices just by wearing the headset due to specially designed speaker cushions. -
Easy Call Management
Jabra headsets with in-line call controller give end users greater productivity and convenience, with large buttons and LCD indicators for quick access. Pick up or end calls, control volume or mute, or simply mule the line. Plus, all buttons are user-programmable. -
Busy light
The Jabra busy light helps you to tope with the challenges of an open office environment and let people clearly know that you are on the phone, the indicator turns red when you are on a call and keeps you from being interrupted. -
Discrete boom arm
Discrete boom arm can be seamlessly integrated into the headband when not on a call or when on the go - so you can easily turn your office headset into a personal headset.
 - Jabra Evolve 40 MS stereo - headset
- Product Type
 - Headset - wired
- Recommended Use
 - Phone, computer
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - Crystal Clear
- Audio Specifications
 - Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
- Impedance
 - 32 Ohm
- Max Input Power
 - 10 mW
- Microphone
 - Boom
- Microphone Technology
 - Electret condenser
- Controls
 - Mute, volume, answer/end
 - 2-year warranty
- Product Type
 - Headset - wired
 - 171.1 g
- Recommended Use
 - Phone, computer
Audio Output
 - On-ear
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - Crystal Clear
 - 150 - 7000 Hz
- Max Input Power
 - 10 mW
- Sensitivity
 - 93.6 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 28 mm
- In-Cord Volume Control
- Adjustable Headband
 - Busy light
Microphone
 - Boom
- Form Factor
 - Headset microphone
 - 10 - 10000 Hz
- Audio Input Details
 - Uni-directional - 10 - 10000 Hz
Remote Control
- Controls
- Connector Type
 - Headset (USB Type-C)
- Included Accessories
 - Carrying pouch, foam inlay
- Cable Details
 - Control cable - 95 cm , Headset cable - 1.2 m
 - Limited warranty - 2 years
- Shipping Width
 - 19 cm
- Shipping Depth
 - 25.5 cm
- Shipping Height
 - 1 cm
                        Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 | In Stock | £47.91 |
