Jabra Evolve 40 Duo UC with 3.5mm Jack Only
Quicklinx: BTCJWS00 Mfr#: 14401-10
More than 50 In Stock
£48.05 ex VAT
£57.66 inc VAT
The Jabra EVOLVE 40 UC duo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Jabra Evolve 40 Stereo - headset
Headset - wired
Recommended Use
Portable electronics, conference
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Microphone
Boom
Headset
Earpad Material
Leatherette
Recommended Use
Headphones
Supraaural
Wired
Available Microphone
Sound Output Mode
Stereo
Microphone
Boom
Connector Type
Headset ( mini-phone stereo 3.5 mm 4-pole )
Headset cable
