The Jabra Evolve 30 MS mono is a professional headset designed mainly to improve conversations. Premium noise cancelling microphone eliminates background noise so your voice can be heard more clearly.
Microsoft Lync optimized with USB adapter that enables easy integration with PC. Built for style and comfort with leatherette ear cushions. Soft pouch included.
NOISE-CANCELLING MIC
State-of-the-art, noise-cancelling microphone eliminates background noise. Your conversation partner won't struggle to hear what you're saying. -
PLUG-AND-PLAY SETUP
Works out of the box with all leading systems. Installation is as easy as simply plugging it in. -
Intuitive control unit for ease of use
Provides easy access to common functions, such as answering or ending calls, controlling volume, and muting conversations. -
Plug-and-play setup for quick user adoption
Works out of the box with any platform. Installation is as easy as simply plugging it in via USB. -
Mass deployment made easy and affordable
Low-end models offer an easy and affordable way to improve your team's concentration. -
Made for voice and music
Truly made for both voice and music with world-class microphone and speakers, so you are free to choose whether you want to be in your own concentration zone or actively participate in voice-based collaboration. -
Passive noise cancellation
Due to specially designed speaker cushions, passive noise cancellation gives you protection from high-frequency noise such as human voices just by wearing the headset.
- Jabra Evolve 30 MS mono - headset
- Product Type
- Headset - wired
- Recommended Use
- Portable electronics, conference
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- Product Type
- Headset - wired
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Mono
- In-Cord Volume Control
Microphone
- Boom
Remote Control
- Headset remote control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
- Included Accessories
- Carrying pouch
- Cable Details
- Headset cable
