Jabra Evolve 30 Duo UC USB Headset
Quicklinx: CB14WS00 Mfr#: 5399-829-309
Recommended Use: Computer, Portable electronics
Connectivity: Wired
Earcover : Binaural
More than 50 In Stock
£50.67 ex VAT
£60.80 inc VAT
The Jabra Evolve 30 is a professional headset, designed to improve conversations. Excellent speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. Simply wear the headset to eliminate high-frequency noise, such as human voices, - all thanks to the specially designed ear cushions. In-line call controller gives you easy access with large buttons and LED indicators. Pick up or end calls, control volume, or simply mute the line.
Jabra Evolve 30 with 3.5 mm jack
In response to popular demand, Jabra is proud to announce the new upgraded Jabra Evolve 30 now with a new USB call control unit with integrated 3.5 mm jack for connectivity to smart devices.
Help your customers speed up their UC adoption with the user friendly Jabra Evolve 30.
  • Noise-canceling mic
    The great noise-canceling microphone eliminates background noise. Your conversation partner won't struggle to hear what you're saying.
  • Plug-and-Play setup
    It works out of the box with most systems. Installation is as easy as simply plugging it in.
  • Intuitive control unit for ease of use
    Provides easy access to common functions, such as answering or ending calls, controlling volume, and muting conversations.
  • Made for voice and music
    Amazing speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks.
  • Passive noise cancellation
    Simply wear the headset to eliminate high-frequency noise, such as human voices - all thanks to the specially designed ear cushions.
  • Easy call management
Jabra Evolve 30 II UC stereo - headset - 3.5 mm jack
Headset - wired - 3.5 mm jack
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance
32 Ohm
Max Input Power
10 mW
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Earpad Material
Leatherette
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Frequency Response
150 - 7000 Hz
Max Input Power
10 mW
Sensitivity
93.6 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
PeakStop technology
Microphone
Boom
Headset microphone
Electret condenser
Sensitivity
-44 dB
Frequency Response
100 - 10000 Hz
Noise Cancelling
Audio Input Details
- 100 - 10000 Hz
Remote Control
Controls
Cable
Cable Length
1.2 m
Carrying pouch
Cable Details
Headset cable - 1.2 m , USB control cable - detachable - 95 cm
Plug and Play, UL, FCC, KCC, RCM
Shipping Width
18 cm
Shipping Depth
23 cm
Shipping Height
3.5 cm
Shipping Weight
171.1 g
CB14 Jabra Evolve LINK USB UC Controller Only In Stock £40.53
CB14 Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units In Stock £34.40
CB14 Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 In Stock £47.91
CB14 Jabra USB-A to USB-C Adapter In Stock £12.40
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
