Jabra Evolve 30 Duo MS USB Headset
Quicklinx: CB17WS00 Mfr#: 5399-823-309
Recommended Use: Computer, Portable electronics
Connectivity: Wired
Earcover : Binaural
£56.32 ex VAT
£67.58 inc VAT
The Jabra Evolve 30 is a professional headset, designed to improve conversations. Excellent speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. Simply wear the headset to eliminate high-frequency noise, such as human voices, - all thanks to the specially designed ear cushions. In-line call controller gives you easy access with large buttons and LED indicators. Pick up or end calls, control volume, or simply mute the line.
Jabra Evolve 30 with 3.5 mm jack
In response to popular demand, Jabra is proud to announce the new upgraded Jabra Evolve 30 now with a new USB call control unit with integrated 3.5 mm jack for connectivity to smart devices.
Help your customers speed up their UC adoption with the user friendly Jabra Evolve 30.
  • Noise-canceling mic
    State-of-the-art, noise-canceling microphone eliminates background noise. Your conversation partner won't struggle to hear, what you're saying.
  • 3.5 mm jack for better connectivity
    The 3.5 mm jack lets users connect to their personal device - such as a smartphone or tablet - to work or listen to music, wherever they may be.
  • Plug and Play setup
    Works out of the box with different systems. Installation is as easy as simply plugging it in.
Jabra Evolve 30 II MS stereo - headset - USB, 3.5 mm jack
Headset - wired - USB, 3.5 mm jack
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance
32 ohm
Max Input Power
10 mW
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Software Certification
Certified for Skype for Business
Earpad Material
Leatherette
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Frequency Response
150 - 7000 Hz
Max Input Power
10 mW
Sensitivity
93.6 dB
Impedance
32 ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
PeakStop technology
Microphone
Boom
Headset microphone
Electret condenser
Sensitivity
-44 dB
Frequency Response
100 - 10000 Hz
Noise Cancelling
Audio Input Details
- 100 - 10000 Hz
Remote Control
Controls
Cable
Cable Length
1.2 m
Carrying pouch
Cable Details
Headset cable - 1.2 m , USB control cable - detachable - 95 cm
Plug and Play, UL, FCC, KCC, RCM
Shipping Width
18 cm
Shipping Depth
23 cm
Shipping Height
3.5 cm
Shipping Weight
171.1 g
CB17 Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units In Stock £45.52
CB17 Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 In Stock £61.76
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
