The Jabra Evolve 30 is a professional headset, designed to improve conversations. Excellent speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. Simply wear the headset to eliminate high-frequency noise, such as human voices, - all thanks to the specially designed ear cushions. In-line call controller gives you easy access with large buttons and LED indicators. Pick up or end calls, control volume, or simply mute the line.
Jabra Evolve 30 with 3.5 mm jack
In response to popular demand, Jabra is proud to announce the new upgraded Jabra Evolve 30 now with a new USB call control unit with integrated 3.5 mm jack for connectivity to smart devices.
Help your customers speed up their UC adoption with the user friendly Jabra Evolve 30.
                Noise-canceling micState-of-the-art, noise-canceling microphone eliminates background noise. Your conversation partner won't struggle to hear, what you're saying.
                3.5 mm jack for better connectivityThe 3.5 mm jack lets users connect to their personal device - such as a smartphone or tablet - to work or listen to music, wherever they may be.
                Plug and Play setupWorks out of the box with different systems. Installation is as easy as simply plugging it in.
- Jabra Evolve 30 II MS stereo - headset - USB, 3.5 mm jack
- Product Type
- Headset - wired - USB, 3.5 mm jack
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
- Impedance
- 32 Ohm
- Max Input Power
- 10 mW
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end
- Software Certification
- Certified for Skype for Business
- 2-year warranty
- Product Type
- Earpad Material
- Leatherette
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- 150 - 7000 Hz
- Max Input Power
- 10 mW
- Sensitivity
- 93.6 dB
- Impedance
- 32 Ohm
- Diaphragm
- 28 mm
- In-Cord Volume Control
- Adjustable Headband
- PeakStop technology
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -44 dB
- 100 - 10000 Hz
- Noise Cancelling
- Audio Input Details
- - 100 - 10000 Hz
Remote Control
- Controls
Cable
- Cable Length
- 1.2 m
- Included Accessories
- Carrying pouch
- Cable Details
- Headset cable - 1.2 m , USB control cable - detachable - 95 cm
- Plug and Play, UL, FCC, KCC, RCM
- Limited warranty - 2 years
- Shipping Width
- 18 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 3.5 cm
- Shipping Weight
- 171.1 g
|  | Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units | In Stock | £34.40 |
|  | Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 | In Stock | £47.91 |
|  | Jabra USB-A to USB-C Adapter | In Stock | £12.40 |
