Jabra Evolve 20 UC Duo MS USB Headset
Quicklinx: D81ZWS00 Mfr#: 4999-829-409
Recommended Use: Phone, Phone
Connectivity: Wired
Earcover : Monaural
£38.21 ex VAT
£45.85 inc VAT
Professional headset with easy call management and great sound for calls and music!
More than headsets, a workplace evolution
With great sound for calls and music, the Evolve 20 and 20 Special Edition are entry-level professional headsets with easy call management through a control unit that makes, takes and mutes calls. Simple connectivity makes it easy to get started with your PC.
Clearer conversation for greater efficiency
Entry-level professional headset with easy call management and great sound for calls and music.
Manage calls easily
Get easy access to the most used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit.
Flexible Plug and Play connectivity
Works straight out of the box. Installation is as easy as simply plugging it in to the USB port on your laptop.
All day comfort (Evolve 20SE)
Built for style and comfort with soft leatherette ear cushions. Adjustable headband lets you find the perfect fit.
Jabra Evolve 20 UC stereo - Special Edition - headset - USB
Headset - wired - USB
Recommended Use
Phone
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Microphone
Boom
Controls
Mute, volume, answer/end
Recommended Use
Phone
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
In-Cord Volume Control
Microphone
Boom
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable Details
Headset cable
D81Z Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 In Stock £62.64
Connectivity: Wired
Earcover : Monaural
Brand: Jabra
