Stay focused, by eliminating distractions in noisy open office environments
The Jabra Evolve series helps you create your own concentration zone with premium active and passive noise cancellation technology - so that you, and not noisy disturbances, are in control. Get further protection from interruptions with the busy light that signals whether or not you are available to colleagues. -
Made for both music and voice
With a world-class set of microphone and speakers that are truly made for both voice communication and music listening, you are free to choose if you want to be in your own concentration zone or actively participate in voice-based collaboration. -
Let you, not the task, decide where you work
Use your headset where you want. Connect easily to your PC via the USB-based control unit. Additionally you can easily change your office headset to a very stylish personal head- set when you're on the go by seamlessly integrating the microphone boom arm into the headband.
 - Jabra Evolve 20 MS stereo - headset - USB-C
- Product Type
 - Headset - wired - USB-C
- Compatibility
 - Mac, Windows
- Recommended Use
 - Computer, portable electronics, phone - communication
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
- Impedance
 - 32 Ohm
- Max Input Power
 - 5 mW
- Noise Isolating
- Microphone
 - Boom
- Microphone Technology
 - Electret condenser
- Controls
 - Mute, volume, answer/end
 - 2-year warranty
- Product Type
- Compatibility
 - Mac, Windows
 - 15.12 cm
 - 5.95 cm
 - 17.04 cm
 - 132 g
- Headband Material
 - Foam
- Earpad Material
 - Foam
- Recommended Use
Audio Output
 - On-ear
 - Wired
- Sound Output Mode
 - Stereo
- Noise Isolating
 - 150 - 7000 Hz
- Max Input Power
 - 5 mW
- Sensitivity
 - 93.6 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 28 mm
- In-Cord Volume Control
- Adjustable Headband
 - Busy light, PeakStop technology
Microphone
 - Boom
- Form Factor
 - Headset microphone
- Sensitivity
 - -44 dB
 - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
 - Headset (24 pin USB-C)
- Included Accessories
 - USB cable
- Cable Details
 - Headset cable - 1.2 m , USB control cable - 95 cm
 - Plug and Play, FCC, KCC, RCM, UL
 - Limited warranty - 2 years
- Shipping Width
 - 18 cm
- Shipping Depth
 - 3.5 cm
- Shipping Height
 - 23 cm
                        Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 | In Stock | £47.91 |
