Professional headset with easy call management and great sound for calls and music!
More than headsets, a workplace evolution
With great sound for calls and music, the Evolve 20 and 20 Special Edition are entry-level professional headsets with easy call management through a control unit that makes, takes and mutes calls. Simple connectivity makes it easy to get started with your PC.
Clearer conversation for greater efficiency
Entry-level professional headset with easy call management and great sound for calls and music.
Manage calls easily
Get easy access to the most used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit.
Flexible Plug and Play connectivity
Works straight out of the box. Installation is as easy as simply plugging it in to the USB port on your laptop.
All day comfort (Evolve 20SE)
Built for style and comfort with soft leatherette ear cushions. Adjustable headband lets you find the perfect fit.
Entry-level professional headset with easy call management and great sound for calls and music. -
Manage calls easily
Get easy access to often used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit. -
Works straight out of the box. Installation is as easy as simply plugging it in to the USB port on your laptop. -
All-day comfort
- Jabra Evolve 20SE MS stereo - Special Edition - headset - USB
- Product Type
- Headset - wired - USB
- Recommended Use
- Computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
- Impedance
- 32 Ohm
- Max Input Power
- 5 mW
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Controls
- Mute, volume, answer/end
- Software Certification
- Certified for Skype for Business
- 2-year warranty
- Product Type
- Earpad Material
- Leatherette
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- 150 - 7000 Hz
- Max Input Power
- 5 mW
- Sensitivity
- 93.6 dB
- Impedance
- 32 Ohm
- Diaphragm
- 28 mm
- In-Cord Volume Control
- PeakStop technology
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -44 dB
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
Cable
- Cable Length
- 1.2 m
- Cable Details
- Headset cable - 1.2 m , USB control cable - 95 cm
- Plug and Play, UL, FCC, KCC, RCM
- Limited warranty - 2 years
- Shipping Width
- 18 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 3.5 cm
Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units | In Stock | £45.52 |
Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 | In Stock | £61.76 |
Jabra USB-A to USB-C Adapter | In Stock | £14.99 |
