Jabra Evolve 20 Mono MS USB Headset
Quicklinx: HGHSWS00 Mfr#: 4993-823-109
Recommended Use: Computer
Connectivity: Wired
Earcover : Monaural
More than 50 In Stock
£25.55 ex VAT
£30.66 inc VAT
Professional headset with easy call management and great sound for calls and music.
  • Stay focused, by eliminating distractions in noisy open office environments
    The Jabra Evolve series helps you create your own concentration zone with premium active and passive noise cancellation technology - so that you, and not noisy disturbances, are in control. Get further protection from interruptions with the busy light that signals whether or not you are available to colleagues.
  • Made for both music and voice
    With a world-class set of microphone and speakers that are truly made for both voice communication and music listening, you are free to choose if you want to be in your own concentration zone or actively participate in voice-based collaboration.
  • Let you, not the task, decide where you work
    Use your headset where you want. Connect easily to your PC via the USB-based control unit or to your smartphone and tablet via the 3.5 mm jack. Additionally you can easily change your office headset to a very stylish personal head- set when you're on the go by seamlessly integrating the microphone boom arm into the headband.
Jabra Evolve 20 MS mono - headset - USB
Headset - wired - USB
Recommended Use
Computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance
32 Ohm
Max Input Power
5 mW
Microphone
Boom
Microphone Technology
Electret condenser
Controls
Mute, volume, answer/end
Software Certification
Certified for Skype for Business
Earpad Material
Foam
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Frequency Response
150 - 7000 Hz
Max Input Power
5 mW
Sensitivity
93.6 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
PeakStop technology
Microphone
Boom
Headset microphone
Electret condenser
Sensitivity
-44 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
1.2 m
Cable Details
Headset cable - 1.2 m , USB control cable - 95 cm
Plug and Play, UL, FCC, KCC, RCM
Shipping Width
18 cm
Shipping Depth
23 cm
Shipping Height
3.5 cm
HGHS Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units In Stock £45.52
HGHS Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 In Stock £62.64
HGHS Jabra Foam Ear Cushion for Jabra EVOLVE 20 65 10 units pack In Stock £13.66
Connectivity: Wired
Earcover : Monaural
Brand: Jabra
