Professional headset with easy call management and great sound for calls and music!
More than headsets, a workplace evolution
With great sound for calls and music, the Evolve 20 and 20 Special Edition are entry-level professional headsets with easy call management through a control unit that makes, takes and mutes calls. Simple connectivity makes it easy to get started with your PC.
Clearer conversation for greater efficiency
Entry-level professional headset with easy call management and great sound for calls and music.
Manage calls easily
Get easy access to the most used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit.
Flexible Plug and Play connectivity
Works straight out of the box. Installation is as easy as simply plugging it in to the USB port on your laptop.
All day comfort (Evolve 20SE)
Built for style and comfort with soft leatherette ear cushions. Adjustable headband lets you find the perfect fit.
Stay focused, by eliminating distractions in noisy open office environments
The Jabra Evolve series helps you create your own concentration zone with premium active and passive noise cancellation technology - so that you, and not noisy disturbances, are in control. Get further protection from interruptions with the busy light that signals whether or not you are available to colleagues. -
Made for both music and voice
With a world-class set of microphone and speakers that are truly made for both voice communication and music listening, you are free to choose if you want to be in your own concentration zone or actively participate in voice-based collaboration. -
Let you, not the task, decide where you work
Use your headset where you want. Connect easily to your PC via the USB-based control unit. Additionally you can easily change your office headset to a very stylish personal head- set when you're on the go by seamlessly integrating the microphone boom arm into the headband.
 - Jabra Evolve 20 MS stereo - headset - USB
- Product Type
 - Headset - wired - USB
- Recommended Use
 - Computer - communication
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - Crystal Clear
- Audio Specifications
 - Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
- Impedance
 - 32 Ohm
- Max Input Power
 - 5 mW
- Microphone
 - Boom
- Microphone Technology
 - Electret condenser
- Controls
 - Mute, volume, answer/end
- Software Certification
 - Certified for Skype for Business
 - 2-year warranty
- Product Type
- Earpad Material
 - Foam
- Recommended Use
Audio Output
 - On-ear
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - Crystal Clear
 - 150 - 7000 Hz
- Max Input Power
 - 5 mW
- Sensitivity
 - 93.6 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 28 mm
- In-Cord Volume Control
 - PeakStop technology
Microphone
 - Boom
- Form Factor
 - Headset microphone
- Sensitivity
 - -44 dB
 - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
 - Headset (4 PIN USB Type A)
Cable
- Cable Length
 - 1.2 m
- Cable Details
 - Headset cable - 1.2 m , USB control cable - 95 cm
 - Plug and Play, UL, FCC, KCC, RCM
 - Limited warranty - 2 years
- Shipping Width
 - 18 cm
- Shipping Depth
 - 23 cm
- Shipping Height
 - 3.5 cm
                        Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units | In Stock | £34.40 |
                        Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 | In Stock | £47.91 |
                        Jabra USB-A to USB-C Adapter | In Stock | £12.40 |
                        Jabra Foam Ear Cushion for Jabra EVOLVE 20 65 10 units pack | In Stock | £11.04 |
