Engage 75 Mono/Stereo
DECT wireless headset with 150 m/490 ft range, up to 13 hours of battery life and integrated busy-light. Can connect to up to five devices simultaneously. Connects to desk phone, softphone, analogue phone, and 2 Bluetooth devices. Meets Skype for Business Open Office requirements.
- Up to 150m range
 - 3x wireless density
 - Advanced noise-cancelling microphone
 - Enhanced speakers with intelligent volume control
 - Up to 13 hours talk-time
 - Integrated busylight
 - Connect up to 5 devices
Industry-leading wireless performance
Provides superior wireless connectivity to a range of 150 metres, enabling 3x more users in the same office space – with no loss in connection quality. Work away from the desk and still maintain a connection that won't let you, or your customers, down. -
Crystal-clear calls
Advanced noise-cancelling microphone and enhanced speakers deliver crystal-clear calls even in noisy offices. -
Connect to up to five devices simultaneously
You can connect to a deskphone, softphone, analogue phone and 2 Bluetooth devices. -
Choice of wearing options to suit every workstyle
Soft ear cushions and additional padding on the headband provide all-day comfort and a secure fit. -
Premium usability and build
Easily answer and end calls, mute and adjust volume using the intuitive controls on the headset.
 - Jabra Engage 75 Stereo - headset
- Product Type
 - Headset - DECT / Bluetooth - wireless - NFC
- Recommended Use
 - Portable electronics, computer, conference
- Localisation
 - Australia, Hong Kong, New Zealand, Singapore, United Kingdom
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wireless
- Wireless Technology
 - DECT / Bluetooth
- Bluetooth Version
 - Bluetooth 5.0
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Frequency Response 40 - 16000 Hz
- Microphone
 - Boom
- Microphone Operation Mode
 - Uni-directional
- Microphone Noise Cancelling
- Microphones Included
 - 2
- Controls
 - Mute, volume, answer/end, reject call
- Software Certification
 - Certified for Skype for Business
 - 2-year warranty
- Product Type
- Dimensions & Weight Details
 - Base: 9.3 cm x 9 cm x 10.6 cm / 218 g
 - 14.1 cm
 - 3.2 cm
 - 16.9 cm
 - 90 g
- Recommended Use
- Max Operating Distance
 - 150 m
- Localisation
Audio Output
 - On-ear
 - Wireless
 - DECT / Bluetooth
- Bluetooth Version
 - Bluetooth 5.0
- Sound Output Mode
 - Stereo
 - 40 - 16000 Hz
- Max Sound Pressure
 - 118 dB
- Diaphragm
 - 28 mm
- In-Cord Volume Control
- Simultaneously Connectable Devices Qty
 - 5
Microphone
 - Boom
 - Uni-directional
 - 2
 - 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
 - Headset , 2 x base unit (5 pin Micro-USB Type B) , Base unit (RJ-45) , 2 x base unit (RJ-9)
- Included Accessories
 - Power adapter, base unit
- Cable Details
 - USB cable - detachable , Phone cable - detachable
- Battery
 - Headset battery rechargeable
- Run Time (Up To)
 - 13 hour(s)
- Recharge Time
 - 90 min
 - Limited warranty - 2 years
