Engage 75 Mono/Stereo
DECT wireless headset with 150 m/490 ft range, up to 13 hours of battery life and integrated busy-light. Can connect to up to five devices simultaneously. Connects to desk phone, softphone, analogue phone, and 2 Bluetooth devices. Meets Skype for Business Open Office requirements.
- Up to 150m range
- 3x wireless density
- Advanced noise-cancelling microphone
- Enhanced speakers with intelligent volume control
- Up to 13 hours talk-time
- Integrated busylight
- Connect up to 5 devices
                Industry-leading wireless performanceProvides superior wireless connectivity to a range of 150 metres, enabling 3x more users in the same office space – with no loss in connection quality. Work away from the desk and still maintain a connection that won't let you, or your customers, down.
                Crystal-clear callsAdvanced noise-cancelling microphone and enhanced speakers deliver crystal-clear calls even in noisy offices.
                Connect to up to five devices simultaneouslyYou can connect to a deskphone, softphone, analogue phone and 2 Bluetooth devices.
                Choice of wearing options to suit every workstyleSoft ear cushions and additional padding on the headband provide all-day comfort and a secure fit.
                Premium usability and buildEasily answer and end calls, mute and adjust volume using the intuitive controls on the headset.
- Jabra Engage 75 Stereo - headset
- Product Type
- Headset - DECT / Bluetooth - wireless - NFC
- Recommended Use
- Portable electronics, computer, conference
- Localisation
- Australia, Hong Kong, New Zealand, Singapore, United Kingdom
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT / Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 40 - 16000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Microphone Noise Cancelling
- Microphones Included
- 2
- Controls
- Mute, volume, answer/end, reject call
- Software Certification
- Certified for Skype for Business
- 2-year warranty
- Product Type
- Dimensions & Weight Details
- Base: 9.3 cm x 9 cm x 10.6 cm / 218 g
- 14.1 cm
- 3.2 cm
- 16.9 cm
- 90 g
- Recommended Use
- Max Operating Distance
- 150 m
- Localisation
Audio Output
- On-ear
- Wireless
- DECT / Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- 40 - 16000 Hz
- Max Sound Pressure
- 118 dB
- Diaphragm
- 28 mm
- In-Cord Volume Control
- Simultaneously Connectable Devices Qty
- 5
Microphone
- Boom
- Uni-directional
- 2
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- Headset , 2 x base unit (5 pin Micro-USB Type B) , Base unit (RJ-45) , 2 x base unit (RJ-9)
- Included Accessories
- Power adapter, base unit
- Cable Details
- USB cable - detachable , Phone cable - detachable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 13 hour(s)
- Recharge Time
- 90 min
- Limited warranty - 2 years
