Jabra Engage 55 Stereo Replacement Headset
Quicklinx: HMT3WS00 Mfr#: 14401-30
One replacement headset for the Jabra Engage 65 or Jabra Engage 75 without base unit. The headset includes headband, ear cushions and padding.
  • Everybody's talking
    Have better conversations, both at home and in the office, with Engage 55. This intuitive headset is designed for those who spend most of their day in calls or virtual meetings, giving you an extensive wireless range and the highest levels of security, for maximum peace of mind. Whether you're working from home or a busy office, Engage 55 will keep you sounding professional for every single conversation, no matter what's happening around you.
  • Wireless range - free range (conversations, not chickens)
    Whether you're working from home or in the office, it's nice to have the freedom to move around. Engage 55's compact USB DECT adapter delivers a wireless range of up to 150 m from your computer, and also makes it easy for you to move about with your laptop while you're on a call. Head to the kitchen for a coffee, or walk a few laps of the office, without worrying about whether your connection will hold.
  • DECT wireless - power, range, security
    DECT wireless is specifically designed for wireless communications, making it an ideal choice for call-intensive workers who need additional mobility. In fact, the DECT wireless range of Engage 55 is up to 15 times the average range of a Class 2 Bluetooth device. And if you're working in a busy office, DECT wireless is built to withstand the density of large numbers of people working in the same place, so you'll get a clear, robust, and secure connection for your conversations.
  • Professional-grade conversations - this sounds serious
    When you're in back-to-back calls or virtual meetings, every word matters. Engage 55 features an impressive noise-canceling microphone that helps block out background noise to keep you sounding like a pro, whichever office you're working from. The speakers are optimized for speech clarity, while wideband audio delivers crisp, crystal clear, natural-sounding calls. So you can wave goodbye to crackly, robotic-sounding voices, and say hello to more engaging conversations.
  • Easy USB connectivity - coffee to call in seconds
    From the moment you first unbox your Engage 55, you're ready to start having seamless, easy calls. Just plug the pre-paired USB DECT adapter into your computer and you're good to go. With this easy-to-use, single-connectivity headset, you're never more than a few seconds from your first call on your computer.
  • Durable adapter - as flexible as your schedule
    Whether you're hot desking or switching it up between home and the office, the durable adapter is built to withstand the demands of your day. It's designed to bend, reducing the risk of damage even if you leave it plugged into your laptop. Perfect for companies with clear desk policies, or workers who like a change of scenery.
  • Lightweight comfort - long-day-proof
    An uncomfortable headset can really distract your focus from the conversation. That's why Jabra has made sure Engage 55 is lightweight, with a low clamping force, to avoid pressure and heat build-up. So even when you're in back-to-back calls all day, you can rely on your headset to help you keep your cool.
  • Sidetone - it's oh so quiet
    Nobody wants to be that guy shouting on all their calls. That's why Engage 55 has adjustable Sidetone built in. By playing a little of your voice into your speakers as you talk, Sidetone helps you to regulate your speech volume, reassuring you that your microphone is working, and combating conversation fatigue.
  • Busylight - protect your focus
    The built-in busylight on Engage 55 helps you wave goodbye to interruptions. Automatically glowing red when you're on a call, it shows anyone nearby that you're in 'do not disturb' mode.
  • Battery and charging - ready when you are
    With long time battery life, you're unlikely to run out of juice mid-flow. But in the unlikely event that you do hear the dreaded "battery low", easy in-call charging means you'll never drop a call. Simply plug the cable in, and carry on the conversation.
Jabra Engage 55 Stereo - headset - replacement
Headset - replacement - DECT - wireless
Compatibility
Mac, Windows
Recommended Use
Computer
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Stereo
Microphone
Boom
Microphone Operation Mode
Uni-directional
Controls
Mute, volume, answer/end, reject call
Environmental Standards
TCO Certified Headsets 9
Engage 55 Stereo, 65 Stereo, 75 Stereo
Headset - DECT - wireless
Replacement
Compatibility
Mac, Windows
83 g
Earpad Material
Leatherette
Recommended Use
Computer
Protection
FIPS 140-2
Max Operating Distance
150 m
Audio Output
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Stereo
Busy light, PeakStop technology, Jabra Direct, Jabra Xpress, SafeToneTM 2.0, IntelliTone 2.0, Speech Level Normalisation, Intelligent Acoustic Shock
Microphone
Boom
Headset microphone
Uni-directional
Remote Control
Controls
Sustainability Information
TCO Certified
Headset battery rechargeable
Run Time (Up To)
13 hour(s)
Jabra Engage 55 Stereo, 65 Stereo, 75 Stereo
