Jabra Electronic Hook Switch headset Adaptor
Quicklinx: 726HWS00 Mfr#: 14201-20
Recommended Use: Accessory
Connectivity: Wired
Earcover : [N/A]
£31.71 ex VAT
£38.05 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
  • 150 Metres Wireless Freedom
    The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Easy to deploy
    The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra EHS Adapter for Alcatel - headset adapter
Cable
Headset adapter
Alcatel 8 Series IPTouch; AVAYA 2410, 5410, 5420, 5610, 6416D+M, 6424D+M, 9620, 9630; Definity 6416D+M; one-X Deskphone Edition 9620, 9630, 9640; one-X Deskphone Value Edition 1608, 1616; Jabra GN9120, GN9330e, GN9350e; PRO 9460, 9470
Cable Type
Headset adapter
C-Tick, NOM, IC, FCC
Alcatel 8 Series IPTouch 4028, 4028 Extended Edition, 4038, 4038 Extended Edition, 4068, 4068 Extended Edition , AVAYA 2410, 5410, 5420, 5610, 6416D+M, 6424D+M, 9620 IP Telephone, 9630 IP Telephone , AVAYA Definity 6416D+M , AVAYA one-X Deskphone Edition 9620 IP Telephone, 9630 IP Telephone, 9640 IP Telephone , AVAYA one-X Deskphone Value Edition 1608, 1616 , Jabra GN9120 Duo, GN9120 Duo Flexboom, GN9330e, GN9330e USB, GN9330e USB for Microsoft Office Communicator 2007, GN9350e , Jabra PRO 9460, 9460 Duo, 9460 NCSA, 9470, 9470 NCSA
Connectivity: Wired
Earcover : [N/A]
Brand: Jabra
Stock Status: In stock
