Jabra EHS 1 Adapter for Avaya
Quicklinx: 7NB9WS00 Mfr#: 14201-19
£41.09 ex VAT
£49.30 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Avaya deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
  • 150 Metres Wireless Freedom
    The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Easy to deploy
    The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra Link 14201-19 - headset adapter - 92.5 cm
Cable
Headset adapter
Cable Length
92.5 cm
Answer/end button, mute switch, volume buttons, Electronic Hook Switch Control (EHS)
1-year warranty
Jabra GN 9120, GN9120, GN9350, GN9350e; GO 6430, 6470
Cable Type
Headset adapter
Cable Length
92.5 cm
Plug and Play, C-Tick, NOM, IC, FCC
Limited warranty - 1 year
Jabra GN 9120 AEI FlexBoom, GN 9120 DG, GN 9120 Flex Accessory Headset, GN 9120 FlexBoom, GN 9120 LR, GN 9120 MicroBoom, GN 9120 Midi Accessory Headset, GN 9120 Midi-Boom, GN 9120 Midi-Boom DHSG, GN 9120 SoundTube, GN 9120 SoundTube Accessory Headset, GN9120 Duo, GN9120 Duo Flexboom, GN9120 Flex, GN9120 Midi, GN9120 MSH Midi, GN9350, GN9350 for Microsoft Office Communicator 2007, GN9350e , Jabra GO 6430, 6470
