Siemens DHSG adapter provides support for remote answer/end calling when used with a Jabra GN9350e, Jabra GN9120-EHS, and Jabra GN9125 Series wireless headsets. Current Siemens phone systems compatible with the Siemens DHSG adapter include the OpenStage 40/60/80, Plus OptiPoint 600, OptiPoint 500 Basic/Std./Adv./Eco. and OptiPoint 410/420 Std./Adv. phone systems.
                150 Metres Wireless FreedomThe Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
                Easy to deployThe Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
                Remote Call ControlAnswer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
- Jabra Siemens DHSG cable - headset cable
- Cable
- Headset cable
- Designed For
- Jabra GN 9120, GN9120, GN9350, GN9350e; GO 6430, 6470
- Cable Type
- Headset cable
- Designed For
- Jabra GN 9120 AEI FlexBoom, GN 9120 DG, GN 9120 Flex Accessory Headset, GN 9120 FlexBoom, GN 9120 LR, GN 9120 MicroBoom, GN 9120 Midi Accessory Headset, GN 9120 Midi-Boom, GN 9120 Midi-Boom DHSG, GN 9120 SoundTube, GN 9120 SoundTube Accessory Headset, GN9120 Duo, GN9120 Duo Flexboom, GN9120 Flex, GN9120 Midi, GN9120 MSH Midi, GN9350, GN9350 for Microsoft Office Communicator 2007, GN9350e , Jabra GO 6430, 6470
