You never need to worry about running out of battery. The Jabra Boost is small and slim, it gives you all the power you need. With long hours of talk time, and long standby time, with the Power Nap feature, this allows you to take calls all day and takes the worry away. No more running out of battery, when you are on-the-go.
Jabra Boost is easy to use. Voice guidance prompts will guide you through the pairing process, tell you when you are low on battery, and even when you connect or disconnect your phone. The intuitive dedicated on/off slider and volume control button makes the headset even easier to handle, so you will never miss a call.
Just leave your smartphone in your pocket - with Jabra Boost, Siri and Google Now are always available at your fingertips. Just tap the dedicated headset button to activate and engage with Siri or Google Now from your smartphone.
Boosting talk time
You never need to worry about running out of battery. The Jabra Boost is small and slim, it gives you all the power you need. With up to 9 hours of talk time, up to 1 year of standby time, and with the new Power Nap feature which allows you to take calls all day and takes the worry away. No more running out of battery when you are on the go. -
Easy to use
Jabra Boost is easy to use. Voice Guidance prompts will guide you through the pairing process, tell you when you are low on battery, and even when you connect or disconnect your phone*. The intuitive dedicated On/Off slider and volume control button makes the headset even easier to handle, so you will never miss a call. *Voice Guidance: English. -
Siri/Google Now at your fingertips
Just leave your smartphone in your pocket – with Jabra Boost, Siri and Google Now are always available at your fingertips. Just tap the dedicated headset button to activate and engage with Siri or Google Now from your smartphone. -
BOOSTING TALK TIME
EASY TO USE
SIRI/GOOGLE NOW AT YOUR FINGERTIPS
- Jabra Boost - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- In-ear - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0 EDR
- Sound Output Mode
- Mono
- Microphone
- Built-in
- Controls
- Volume, on/off, answer/end
- 1-year warranty
- Product Type
- 1.45 cm
- 4.93 cm
- 0.95 cm
- 8.5 g
- Black
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Mono
- Diaphragm
- 11 mm
Microphone
- Frequency Response
- 200 - 6800 Hz
- Audio Input Details
- Omni-directional
Remote Control
- Controls
Wireless Link
- Transmission Range
- 30 m
- Connector Type
- USB (5 pin Micro-USB Type B (power only))
- Included Accessories
- Ear tips kit, 2 earhooks
- Cable Details
- USB charge cable
- GOST, IC, FCC, RoHS, REACH
- Power Device
- Power adapter - car - external
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 9 hour(s)
- Standby Time
- 216 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 1 year
