Jabra Biz 2300 Mono, USB-C, UC
Quicklinx: DL87WS00 Mfr#: 2393-829-189
Recommended Use: Phone, Phone
Connectivity: Wired
Earcover : Monaural
Select:
£93.66 ex VAT
£112.39 inc VAT
Your contact centre agents are your brand ambassadors, so give them the tool to sound as clear as your brand. In Jabra's Biz 2300, world-class sound meets world-class durability in an exceptionally comfortable and stylish corded headset – keeping both your agents and your customers happy.
  • All-day comfort for agents
    Extremely lightweight and unobtrusive design means lowered agent fatigue and more productive calls. Weighs just 49 grams in the mono version, and just 68 grams in duo The adjustable headband and microphone boom-arm let you find the perfect fit The control unit lets you change volume, mute your calls and more PeakStop? technology removes sudden loud sounds or tones before they reach your ears: Any sound above 118 db is filtered out.
  • World-class sound
    Lifelike conversations and higher customer satisfaction require both great, ambient-noise reducing sound in the agent's ears, and a noise-cancelling microphone that also avoids air shocks. The Jabra Biz 2300 has both. HD Voice technology makes sure you clearly understand the other party The speakers reduce ambient noise, so you can focus on the call Specially designed ?air shock? noise-cancelling mic filters out sharp breathing sounds and popping noises often heard in conversations.
  • Air shock microphone
    When the microphone is close to the mouth of the user, there is a risk of respiratory noise. To reduce this, the microphone is designed aerodynamically and with many small holes instead of one larger hole. In addition, foam is included on the inside of the microphone. Overall, it reduces the penetration of air shocks to the microphone, which optimises the call quality.
Jabra BIZ 2300 QD Mono - headset - USB-C
Headset - wired - USB-C
Recommended Use
Phone
Headphones Form Factor
On-ear - convertible
Wired
Sound Output Mode
Mono
Microphone
Boom
Environmental Standards
TCO Certified Headsets 9
49 g
Recommended Use
Phone
Audio Output
Wired
Sound Output Mode
Mono
Adjustable Headband
Microphone
Boom
Headset microphone
Connector Type
Headset (USB Type-C)
Cable Details
Headset cable - Kevlar reinforced
Sustainability Information
TCO Certified
DL87 Jabra GN QD Cord With RJ45 Plug For Siemens Openstage In Stock £15.99
DL87 Jabra Ear Cushion, Foam For BIZ 2300, Pack 10 In Stock £15.25
DL87 Jabra Link 260 USB-amplifier QD to USB In Stock £81.37
Connectivity: Wired
Earcover : Monaural
Brand: Jabra
