Your contact centre agents are your brand ambassadors, so give them the tool to sound as clear as your brand. In Jabra's Biz 2300, world-class sound meets world-class durability in an exceptionally comfortable and stylish corded headset – keeping both your agents and your customers happy.
A headset that's built to last
The Jabra Biz 2300 is built to survive in a high-performing contact centre, meaning fewer headset replacements and less downtime for you and your team and lower total cost of ownership. Reinforced cord is built to withstand the contact centre environment and is protected against office chair wheels, sharp objects and daily use The boom-arm can be rotated 360 degrees with zero risk of breaking. We call this FreeSpin . -
All-day comfort for agents
Extremely lightweight and unobtrusive design means lowered agent fatigue and more productive calls. Weighs just 49 grams in the mono version, and just 68 grams in duo The adjustable headband and microphone boom-arm let you find the perfect fit The control unit lets you change volume, mute your calls and more PeakStop technology removes sudden loud sounds or tones before they reach your ears: Any sound above 118 db is filtered out. -
World-class sound
Lifelike conversations and higher customer satisfaction require both great, ambient-noise reducing sound in the agent's ears, and a noise-cancelling microphone that also avoids air shocks. The Jabra Biz 2300 has both. HD Voice technology makes sure you clearly understand the other party The speakers reduce ambient noise, so you can focus on the call Specially designed "air shock" noise-cancelling mic filters out sharp breathing sounds and popping noises often heard in conversations. -
Air shock microphone
When the microphone is close to the mouth of the user, there is a risk of respiratory noise. To reduce this, the microphone is designed aerodynamically and with many small holes instead of one larger hole. In addition, foam is included on the inside of the microphone. Overall, it reduces the penetration of air shocks to the microphone, which optimises the call quality.
- Jabra BIZ 2300 MS QD Mono - headset - USB-C
- Product Type
- Headset - wired - USB-C
- Recommended Use
- Phone
- Headphones Form Factor
- On-ear - convertible
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Microphone
- Boom
- Product Type
- 49 g
- Recommended Use
- Phone
Audio Output
- Wired
- Sound Output Mode
- Mono
- Adjustable Headband
Microphone
- Boom
- Form Factor
- Headset microphone
- Connector Type
- Headset (USB Type-C)
- Cable Details
- Headset cable - Kevlar reinforced
Jabra Link 260 USB-amplifier QD to USB | In Stock | £81.37 |
