The Jabra BIZ 1500 is an entry level, low-cost, professional corded headset with Jabra’s leading noise-cancellation technology. Designed for comfortable all-day wear.
Great sound
- Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
- HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
- Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
- Headband and microphone boom can be adjusted to suit your preference.
Tough Design
- Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking.
Great sound
Noise-cancelling air shock microphone reduces background noise and sharp breathing sounds - ideal for crowded open offices. HD Voice makes your conversations sound vibrant and lifelike. -
All-day comfort
Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears. Headband and microphone boom can be adjusted to suit your preference. -
Tough design
- Jabra BIZ 1500 Mono - headset - Quick Disconnect
- Product Type
- Headset - wired - Quick Disconnect
- Recommended Use
- Phone
- Localisation
- EMEA
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
- Impedance
- 300 ohm
- Max Input Power
- 30 mW
- Microphone
- Boom
- 2-year warranty
- Product Type
- 13.1 cm
- 5.7 cm
- 16.5 cm
- 88 g
- Earpad Material
- Foam
- Recommended Use
- Phone
- Localisation
- EMEA
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Mono
- 20 - 4500 Hz
- Max Input Power
- 30 mW
- Sensitivity
- 115.5 dB/mW
- Impedance
- 300 ohm
Microphone
- Boom
- Sensitivity
- -32 dBV/Pascal
- 1000 - 5000 Hz
- Audio Input Details
- Uni-directional - 1000 - 5000 Hz
- Connector Type
- Headset (Quick Disconnect)
Cable
- Cable Length
- 95 cm
- Cable Details
- Headset cable - 95 cm
- Limited warranty - 2 years
Jabra GN1200 Smartcord (Curly) - for Desk Phone Connectivity | In Stock | £30.49 |
Jabra Link 260 USB-amplifier QD to USB | In Stock | £81.37 |
Jabra LINK 860 Amplifier | In Stock | £128.47 |
