Jabra BIZ 1500 Duo USB headset is a professional grade entry level USB Computer headsets with excellent value for call centers. It comes complete with a USB plug for instant plug-and-play computer connection, letting you benefit from its clear sound and low cost of ownership. Equipped with a noise-cancelling microphone and HD quality sound. Its light weight headband provide all day comfort for your call-intensive office.
Great sound
- Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
- HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
- Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
- Headband and microphone boom can be adjusted to suit your preference.
Tough Design
- Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking.
Great sound
Noise-cancelling air shock microphone reduces background noise and sharp breathing sounds - ideal for crowded open offices. HD Voice makes your conversations sound vibrant and lifelike. -
All-day comfort
Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears. Headband and microphone boom can be adjusted to suit your preference. -
Tough design
- Jabra BIZ 1500 Duo - headset - USB
- Product Type
- Headset - wired - USB
- Recommended Use
- Phone
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
- Impedance
- 150 ohm
- Max Input Power
- 30 mW
- Microphone
- Boom
- 2-year warranty
- Product Type
- 13.1 cm
- 5.7 cm
- 16.5 cm
- 146 g
- Earpad Material
- Foam
- Recommended Use
- Phone
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 4500 Hz
- Max Input Power
- 30 mW
- Sensitivity
- 115.5 dB/mW
- Impedance
- 150 ohm
Microphone
- Boom
- Sensitivity
- -32 dBV/Pascal
- 1000 - 5000 Hz
- Audio Input Details
- Uni-directional - 1000 - 5000 Hz
- Connector Type
- USB (4 PIN USB Type A)
Cable
- Cable Length
- 95 cm
- Cable Details
- Headset cable - 95 cm
- Limited warranty - 2 years
