Jabra BIZ 1500 Duo USB Wideband Headset
Quicklinx: C1Z9WS00 Mfr#: 1559-0159
Recommended Use: Phone, Phone
Connectivity: Wired
Earcover : Binaural
£54.73 ex VAT
£65.67 inc VAT
Jabra BIZ 1500 Duo USB headset is a professional grade entry level USB Computer headsets with excellent value for call centers. It comes complete with a USB plug for instant plug-and-play computer connection, letting you benefit from its clear sound and low cost of ownership. Equipped with a noise-cancelling microphone and HD quality sound. Its light weight headband provide all day comfort for your call-intensive office.
Great sound
  • Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
  • HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
  • Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
  • Headband and microphone boom can be adjusted to suit your preference.
Tough Design
  • Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking.
  • Great sound
    Noise-cancelling air shock microphone reduces background noise and sharp breathing sounds - ideal for crowded open offices. HD Voice makes your conversations sound vibrant and lifelike.
  • All-day comfort
    Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears. Headband and microphone boom can be adjusted to suit your preference.
  • Tough design
Jabra BIZ 1500 Duo - headset
Headset - wired - USB
Recommended Use
Phone
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
Impedance
150 Ohm
Max Input Power
30 mW
Microphone
Boom
13.1 cm
5.7 cm
16.5 cm
146 g
Earpad Material
Foam
Recommended Use
Phone
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 4500 Hz
Max Input Power
30 mW
Sensitivity
115.5 dB/mW
Impedance
150 Ohm
Microphone
Boom
Sensitivity
-32 dBV/Pascal
Frequency Response
1000 - 5000 Hz
Audio Input Details
Uni-directional - 1000 - 5000 Hz
Connector Type
USB (4 PIN USB Type A)
Cable
Cable Length
95 cm
Cable Details
Headset cable - 95 cm
C1Z9 Jabra USB-A to USB-C Adapter In Stock £12.40
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
