Jabra Aeroplane Entertainment System Jack converter for Jabra Evolve Headsets Converts 2 pin Aeroplane Entertainment system to 3.5mm Jack Pack of 6
Versatile connectivity
Designed to enhance your in-flight entertainment experience, the Jabra Flight adapter features a 90° angled connector and a unique configuration that allows for easy connection to airplane audio systems. With both male and female connectors, it ensures compatibility with a wide range of headphones and airline systems. -
Compact design
The Jabra Flight's compact and lightweight design makes it an essential travel accessory. Its 90° connector design minimizes strain on the cable, ensuring durability and reliability during travel.
- Jabra Flight - airplane audio adapter
- Cable
- Airplane audio adapter
- Packaged Quantity
- 6 (specifications are for single item)
- Connector
- 2 x mono mini jack - male
- Connector (Second End)
- Mini-phone stereo 3.5 mm - female
- 90° connector
- Packaged Quantity
- Cable Type
- Airplane audio adapter 90° connector
- Connector
- 2 x mini-phone mono 3.5 mm - male
