The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
Self-destruct feature
You can pre-program the diskAshur2 with your own unique self-destruct PIN, which once implemented, instantly deletes the encryption key, all PINs, data and then creates a new encryption key. -
Auto lock
The diskAshur2 automatically locks when unplugged from the host computer or power to the USB port is turned off and can also be set to automatically lock after a predetermined amount of time. -
Data at rest protection
All data and encryption keys are always encrypted whilst at rest. -
Wear resistant epoxy coated keypad
Designed with protection in mind, the diskAshur2 wear resistant epoxy coated keypad hides key usage to avoid tipping off a potential hacker to commonly used keys.
- iStorage diskAshur² - SSD - 1 TB - USB 3.1 - TAA Compliant
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- FIPS 197, 256-bit AES-XTS
- Interface
- USB 3.1
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Wear Resistant Keypad, Brute Force Hack Defence Mechanism, OS & platform independent
- Power Source
- USB bus
- Enclosure Colour
- Racing green
- 84 mm x 124 mm x 19 mm
- 180 g
- TAA Compliant
- 3-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.1
- 84 mm
- 124 mm
- 19 mm
- 180 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 294 MBps (read) / 319 MBps (write)
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 9 pin USB Type B
- Power Source
- USB bus
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB 3.1 cable - integrated
- FCC, RoHS, WEEE
- Enclosure Colour
- Racing green
- TAA Compliant
- Limited warranty - 3 years
