Looking for an effortless way to secure your data while taking advantage of the fastest USB 3.0 speeds? Look no further than the diskAshur, the fast of iStorage's secure drive line. With the same easy-to-use keypad design and software free setup, the diskAshur enables you to access the drive with your own unique pin but now at data transfer speeds of up to 5 Gbps.
Self-destruct feature
You can pre-program the diskAshur2 with your own unique self-destruct PIN, which once implemented, instantly deletes the encryption key, all PINs, data and then creates a new encryption key. -
Auto lock
The diskAshur2 automatically locks when unplugged from the host computer or power to the USB port is turned off and can also be set to automatically lock after a predetermined amount of time. -
Data at rest protection
All data and encryption keys are always encrypted whilst at rest. -
Wear resistant epoxy coated keypad
Designed with protection in mind, the diskAshur2 wear resistant epoxy coated keypad hides key usage to avoid tipping off a potential hacker to commonly used keys.
- iStorage diskAshur² - hard drive - 1 TB - USB 3.1 Gen 1 - TAA Compliant
- Hard drive - external (portable)
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES, FIPS 197
- Interface
- USB 3.1 Gen 1
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- Wear Resistant Keypad, Brute Force Hack Defence Mechanism, government certified, OS & platform independent, 256-bit AES-XTS
- Power Source
- USB bus
- Enclosure Colour
- Racing green
- 12.4 cm x 8.4 cm x 1.9 cm
- 216 g
- TAA Compliant
- 3-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.1 Gen 1
- Buffer Size
- 8 MB
- 12.4 cm
- 8.4 cm
- 1.9 cm
- 216 g
Performance
- Interface Transfer Rate
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 9 pin USB Type A
- Power Source
- USB bus
- OS Required
- Apple MacOS, Linux, Microsoft Windows
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB 3.1 cable - integrated
- FCC, RoHS, WEEE
- Enclosure Colour
- Racing green
- TAA Compliant
- Limited warranty - 3 years
