In fact, it will work on any device with a USB port! One of the unique and underlying security features of the GDPR compliant diskAshur PRO2 is the dedicated hardware based secure microprocessor (Common Criteria EAL4+ ready), which employs built-in physical protection mechanisms designed to defend against external tamper, bypass attacks and more. Unlike other solutions, the diskAshur PRO2 reacts to an automated attack by entering the deadlock frozen state, which renders all such attacks as useless. In plain and simple terms, without the PIN there's no way in!
EDGETM (Enhanced Dual Generating Encryption) technology
Offering advanced portable data security via built-in FIPS PUB 197 validated AES 256-bit XTS hardware encryption engine. The data encryption key is randomly generated by a Common Criteria EAL4+ ready Random Number Generator and protected by NCSC, FIPS and Common Criteria validated wrapping algorithms. Uniquely featuring a dedicated on-board Common Criteria EAL4+ ready secure microprocessor to enhance security through true random number generation and built-in cryptography. The security component employs physical protection mechanisms to protect itself from any external tamper, bypass laser attacks and fault injections and incorporates active-shield violation technology. More specifically, the secure microprocessor reacts to all forms of automated hacking attempts by entering the deadlock frozen state where the device can only restart through a "Power On" reset procedure (i.e. power off/power on). The security lock feature protects the device against any unauthorized firmware modifications from the host side (fully protected against BadUSB). The diskAshur PRO2 uniquely incorporates a secure microprocessor providing secure algorithms to encrypt both the data and the encryption key, giving you confidence that your data is protected to the highest standards at any given time. -
FIPS PUB 197 validated encryption algorithm
Employing AES 256-bit XTS hardware encryption, the iStorage diskAshur PRO2 seamlessly encrypts all data on the drive in real-time, keeping your data safe even if the hard drive is removed from its enclosure. -
Super fast USB 3.1
With super-fast USB 3.1 data transfer speeds of 148 MBps (Read) and 140 MBps (Write), you can now access your files faster than ever before. The iStorage diskAshur PRO2 is also backwards compatible with USB 2.0 and 1.1 ports. -
Brute force hack defense mechanism
The iStorage diskAshur PRO2 is intelligently programmed to protect against all forms of Brute Force attacks. After five consecutive incorrect PIN entries the drive will freeze, requiring the drive to be disconnected and reconnected to the USB port to get a further five PIN entry attempts. If a further five (10 in total) consecutive incorrect PIN attempts are entered again, the diskAshur PRO2 will freeze again. To get a further and final five PIN attempts (15 in total), the "shift" button must be pressed whilst inserting the USB cable to the USB port and then an iStorage preset PIN will need to be entered. On the fifteenth consecutive incorrect PIN entry, the diskAshur PRO2 assumes it is being attacked and will delete the encryption key and lock itself, rendering all data previously stored on the drive as lost forever. At this point the drive can be reset to factory default settings and redeployed.
- iStorage diskAshur PRO² - solid state drive - 1 TB - USB 3.1 - TAA Compliant
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- FIPS 197, 256-bit SHA, 256-bit AES-XTS
- Interface
- USB 3.1
- Data Transfer Rate
- 5.0 Gbps (USB 3.1 Gen 1)
- Wear Resistant Keypad, Brute Force Hack Defence Mechanism, government certified, OS & platform independent
- Power Source
- USB bus
- 84 mm x 124 mm x 20 mm
- 225 g
- TAA Compliant
- 3-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.1
- 84 mm
- 124 mm
- 20 mm
- 225 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 148 MBps (read) / 140 MBps (write)
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 9 pin USB Type A
- Power Source
- USB bus
- Cables Included
- 1 x USB 3.1 cable - integrated
- FCC, RoHS, WEEE
- TAA Compliant
- Limited warranty - 3 years
