istorage diskAshur DT2 256-bit 2TB - Classified - Graphite
Quicklinx: CX8FWS00 Mfr#: IS-DT2-256-2000-C-G
Form Factor: [N/A]
Capacity: 2TB
Interface: [N/A]
16 In Stock
£173.26 ex VAT
£207.91 inc VAT
Marketing description is not available.
  • Easy to use
    Simply enter a 7-15 digit PIN to authenticate and use as a normal external drive. When the drive is disconnected, all data is encrypted using AES-XTS 256-bit hardware encryption.
  • Tamper proof
    All data stored on the diskAshur DT² is encrypted using FIPS PUB 197 validated, AES-XTS 256-bit hardware encryption. All components incorporated within the diskAshur DT² are completely covered by a layer of super tough epoxy resin, which is virtually impossible to remove without causing permanent damage to the components. The drive is also designed to be tamper evident making it obvious to the User if it has been pried open and tampered with.
  • Wear resistant keypad
    The onboard keypad is covered with a layer of polymer coating that protects the keys and hides key usage to avoid tipping off a potential hacker to commonly used keys.
  • Transfer your files in seconds
    Lightning fast backwards compatible USB 3.2 data transfer speeds.
iStorage diskAshur DT² - hard drive - 2 TB - USB 3.1 - TAA Compliant
Hard drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
FIPS 197, 256-bit SHA, 256-bit AES-XTS
USB 3.1
Data Transfer Rate
5.0 Gbps (USB 3.0)
Wear Resistant Keypad, Brute Force Hack Defence Mechanism, government certified, OS & platform independent
Power Source
USB bus
11.2 mm x 18.55 mm x 4.35 mm
TAA Compliant
3-year warranty
2 TB
Hardware Encryption
USB 3.1
11.2 mm
18.55 mm
4.35 mm
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Internal Data Rate
225 MBps (read) / 223 MBps (write)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B
Power Source
USB bus
Power adapter
DC 12 V
USB cable
FCC, RoHS, WEEE
TAA Compliant
Limited warranty - 3 years
Form Factor: [N/A]
Capacity: 2TB
Interface: [N/A]
Brand: istorage
