Easy to use
Simply enter a 7-15 digit PIN to authenticate and use as a normal external drive. When the drive is disconnected, all data is encrypted using AES-XTS 256-bit hardware encryption. -
Tamper proof
All data stored on the diskAshur DT² is encrypted using FIPS PUB 197 validated, AES-XTS 256-bit hardware encryption. All components incorporated within the diskAshur DT² are completely covered by a layer of super tough epoxy resin, which is virtually impossible to remove without causing permanent damage to the components. The drive is also designed to be tamper evident making it obvious to the User if it has been pried open and tampered with. -
Wear resistant keypad
The onboard keypad is covered with a layer of polymer coating that protects the keys and hides key usage to avoid tipping off a potential hacker to commonly used keys. -
Transfer your files in seconds
Lightning fast backwards compatible USB 3.2 data transfer speeds.
 - iStorage diskAshur DT² - hard drive - 1 TB - USB 3.1 - TAA Compliant
 - Hard drive - external (portable)
- Capacity
 - 1 TB
- Hardware Encryption
- Encryption Algorithm
 - FIPS 197, 256-bit SHA, 256-bit AES-XTS
- Interface
 - USB 3.1
- Data Transfer Rate
 - 5.0 Gbps (USB 3.0)
 - Brute Force Hack Defence Mechanism, government certified, OS & platform independent, Wear Resistant Keypad
- Power Source
 - USB bus
 - 11.2 mm x 18.55 mm x 4.35 mm
- TAA Compliant
 - 3-year warranty
- Capacity
 - 1 TB
- Interface
 - USB 3.1
 - 11.2 mm
 - 18.55 mm
 - 4.35 mm
Performance
- Interface Transfer Rate
- Internal Data Rate
 - 225 MBps (read) / 223 MBps (write)
Expansion & Connectivity
 - 1 x USB 3.0 - 9 pin USB Type B
- Power Source
 - USB bus
- Power Device
 - Power adapter
- Voltage Required
 - DC 12 V
- Cables Included
 - USB cable
 - FCC, RoHS, WEEE
- TAA Compliant
 - Limited warranty - 3 years
