istorage diskAshur Desktop USB 3.0 256-bit 8TB
Quicklinx: C12LWS00 Mfr#: IS-DA-256-8000
The iStorage desktop secure hard drive utilizes military grade AES 256-bit hardware encryption, which encrypts all data stored on the drive in real time. Should the drive be lost or stolen, the user can rest assured that all data held on the drive is safe and cannot be accessed by any unauthorized third party, even if the hard drive is removed from its enclosure.
iStorage diskAshur DT - hard drive - 8 TB - USB 3.0
Hard drive - external (desktop)
8 TB
Hardware Encryption
Encryption Algorithm
256-bit AES, FIPS 197
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Spindle Speed
5900 rpm
Built-in keypad, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Wear Resistant Keypad, NTFS formatted, on/off switch, PIN code authentication, 256-bit AES
Power Source
Included AC adapter
11.43 cm x 18.288 cm x 3.81 cm
8 TB
Hardware Encryption
USB 3.0
Buffer Size
8 MB
11.43 cm
18.288 cm
3.81 cm
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Seek Time
12 ms (average)
Spindle Speed
5900 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B
Power Source
Included AC adapter
Power adapter
Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS
1 x USB cable - external
Enclosure Material
Aluminium
FCC, RoHS, WEEE
Shock Tolerance (operating)
300 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 1 ms
