istorage datAshur Pro USB 3.0 256-bit 8GB
Quicklinx: C12GWS00 Mfr#: IS-FL-DA3-256-8
Capacity: 8GB
Interface: USB 3.0
Hurry, only 2 left in stock!
£74.91 ex VAT
£89.89 inc VAT
The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
iStorage datAshur PRO - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
8 GB
Hardware Encryption
Encryption Algorithm
256-bit AES-XTS, 256-bit SHA, FIPS 140-2 Level 3, FIPS 197
Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS
3-year warranty
USB flash drive
Storage Capacity
8 GB
Hardware Encryption
Read Rate
Up to 116 MB/s
Write Rate
Up to 43 MB/s
Interface Type
USB 3.0
Brute Force Hack Defence Mechanism, wear-resistant keypad, government certified, OS & platform independent
Protective sleeve
Limited warranty - 3 years
78 mm
18 mm
8 mm
25 g
Capacity: 8GB
Interface: USB 3.0
Brand: istorage
