The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
 - iStorage datAshur PRO - USB flash drive - 16 GB
- Product Type
 - USB flash drive
- Interface Type
 - USB 3.0
- Storage Capacity
 - 16 GB
- Hardware Encryption
- Encryption Algorithm
 - FIPS 197, 256-bit SHA, 256-bit AES-XTS
- OS Required
 - Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS
 - 3-year warranty
- Product Type
 - USB flash drive
- Storage Capacity
 - 16 GB
- Read Rate
 - Up to 116 MB/s
- Write Rate
 - Up to 43 MB/s
- Interface Type
 - USB 3.0
 - Brute Force Hack Defence Mechanism, wear-resistant keypad, government certified, OS & platform independent
- Included Accessories
 - Protective sleeve
- OS Required
 - Limited warranty - 3 years
 - 78 mm
 - 18 mm
 - 8 mm
 - 25 g
