istorage datAshur 30GB Secure USB 3.0 Solid State Flash Drive
Quicklinx: BBJLWS00 Mfr#: IS-FL-DA-SSD-30
With the datAshur SSD's advanced security features such as read-only mode, auto-lock, self-destruct PIN and brute force protection, delivers complete data security and guarantees 100% protection of your data.
  • Read only mode
    Administrator mode allows the setup of a 'read only' user mode so that data can only be read from datAshur SSD protecting the data from accidental deletion and changes to the file's content.
  • Utilizes military grade 256-bit AES XTS hardware encryption
    All data on the datAshur SSD is encrypted on-the-fly with the built-in XTS-AES 256-bit hardware encryption.
  • Onboard alphanumeric keypad - prevents hardware and software key logging
    Using a rechargeable battery, the datAshur SSD enables the user to unlock the drive with a 7-16 digit PIN before connecting to the USB port on your computer, tablet or mobile device. The embedded keypad prevents hardware and software key logging attempts to capture your password entered via the host system.
  • Software-free design
    With no admin rights to contend with, the datAshur SSD is a breeze to implement.
  • Independent user and admin PINs
    The datAshur SSD can be configured with independent User and admin PINs, making it ideal for corporate and government deployment. If the user forgets their PIN, the drive can be unlocked using the admin PIN which can then clear the forgotten user PIN and allow for the user to set a new PIN.
  • Drive reset feature
    The datAshur SSD also includes a drive reset feature which clears both User and admin PINs, destroys the data, creates a randomly generated encryption key and allows the drive to be reused. The datAshur SSD is capable of generating an infinite number of randomly generated encryption keys, allowing the user to reset the drive as often as required.
  • Dust and water resistant durable aluminum housing - IP58 certification
    Protecting data goes well beyond encryption. Tough enough to go anywhere, the datAshur SSD's resilient design makes it perfect for travel and field applications. With its rugged, extruded aluminum crush-resistant casing, the datAshur SSD is tamper evident and well-protected against physical damage.
  • Sealed from physical attacks by tough epoxy coating
    The internal drive components are completely protected by a super tough epoxy compound, making it virtually impossible to remove without causing permanent damage to the electronics. This barrier prevents a potential hacker from accessing the encryption circuitry and launching a variety of potential attacks.
  • Brute force self destruct feature
    As the datAshur SSD is unlocked using its own keypad and not via a keyboard, it is not vulnerable to software/hardware based key-loggers or brute force attacks. In addition the datAshur SSD further protects your data with a programmable "brute force hack defense mechanism" which deletes the encryption key and destroys all stored data if the incorrect PIN is entered up to a total of 20 consecutive times.
  • Unattended auto lock feature
    The datAshur SSD automatically locks once you unplug the drive from your computer's USB port or power to the USB port is turned off or after a pre-programmed period of inactivity
  • Wear resistant key pad
    Designed with protection in mind, the entire iStorage family incorporates'wear resistant' keypads to hide key usage and avoid tipping off a potential hacker to the commonly used keys.
  • Lock override mode
    Designated for specific cases in which the datAshur SSD needs to remain unlocked through USB port re-enumeration such as during reboot, or passing through a virtual machine. With the toughness and security you'd expect from iStorage, the datAshur SSD brings features, speed, and storage capacities that you'd never expect in a flash drive.
iStorage datAshur SSD - USB flash drive - 30 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
30 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, FIPS 197, 256-bit SHA, 256-bit AES-XTS
Apple MacOS, Linux, Microsoft Windows, Android
3-year warranty
USB flash drive
Storage Capacity
30 GB
Hardware Encryption
Read Rate
Up to 195 MB/s
Write Rate
Up to 162 MB/s
Interface Type
USB 3.0
Water resistant, dustproof, auto-locking, customizable PIN, ruggedized, Read-Only Access Mode, brute-force protection, Self-Destruct PIN, boot delay, drive reset, Onboard Alphanumeric Keypad, Lock Override Mode, epoxy internal filling
Protective sleeve
Plug and Play, FCC, RoHS, IP57, IP58
Limited warranty - 3 years
24.5 mm
12.6 mm
93 mm
46 g
