istorage 8GB datashur 256-bit Military Hardware Encryption USB Flash
Quicklinx: 7R6LWS00 Mfr#: IS-FL-DA-256-8
Capacity: 8GB
Interface: USB 2.0
£52.33 ex VAT
£62.79 inc VAT
The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
iStorage datAshur - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
8 GB
Hardware Encryption
Encryption Algorithm
256-bit AES, 256-bit SHA
Apple MacOS, Linux, Microsoft Windows, Symbian OS, Android
3-year warranty
USB flash drive
Storage Capacity
8 GB
Hardware Encryption
Read Rate
Up to 27 MB/s
Write Rate
Up to 24 MB/s
Interface Type
USB 2.0
Brute Force Hack Defence Mechanism, wear-resistant keypad, government certified, OS & platform independent
FCC, RoHS, WEEE
Limited warranty - 3 years
20 mm
80 mm
10.5 mm
25 g
Capacity: 8GB
Interface: USB 2.0
Brand: istorage
