Product
istorage 32GB datAshur 256-bit Flash Memory
Quicklinx: 8QPWWS00 Mfr#: IS-FL-DA-256-32
Capacity: 32GB
Interface: USB 2.0
More than 50 in stock
£83.17 ex VAT
£99.80 inc VAT
The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
iStorage datAshur - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
256-bit AES, 256-bit SHA
Apple MacOS, Linux, Microsoft Windows, Symbian OS, Android
3 years warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 27 MB/s
Write Rate
Up to 24 MB/s
Interface Type
USB 2.0
Brute Force Hack Defence Mechanism, wear-resistant keypad, government certified, OS & platform independent
Plug and Play, FCC, RoHS, WEEE, MIL-STD-810F
Limited warranty - 3 years
78 mm
18 mm
10.5 mm
25 g
Capacity: 32GB
Interface: USB 2.0
Brand: istorage
Price Range Ex VAT: 50 - 100
