The iStorage desktop secure hard drive utilizes military grade AES 256-bit hardware encryption, which encrypts all data stored on the drive in real time. Should the drive be lost or stolen, the user can rest assured that all data held on the drive is safe and cannot be accessed by any unauthorized third party, even if the hard drive is removed from its enclosure.
- iStorage diskAshur DT - hard drive - 2 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- FIPS 197
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Buffer Size
- 8 MB
- Spindle Speed
- 7200 rpm
- Built-in keypad, password authentication, hardware encryption, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, 256-bit AES, 128-bit AES
- Power Source
- Included AC adapter
- 11.4 cm x 18.3 cm x 3.8 cm
- 3-year warranty
- Capacity
- 2 TB
- FIPS 197
- Interface
- USB 3.0
- Buffer Size
- 8 MB
- 11.4 cm
- 18.3 cm
- 3.8 cm
Performance
- Interface Transfer Rate
- Seek Time
- 12 ms (average)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type B
- Power Source
- Power Device
- Power adapter
- Cables Included
- 1 x USB cable - external
- FCC, RoHS, WEEE
- Limited warranty - 3 years
- Shock Tolerance
- 300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
