We live and work in a mobile world, and you need to make sure your data is always available no matter where you go. But you can't entrust your most sensitive and confidential information to just any flash drive. A poorly made drive won't stand up to heavy use or break-in attempts, and drives selected on price alone could leave your valuable information vulnerable to corruption, infection or theft. For an easy-to-use and reliable way to protect your most sensitive data, turn to the IronKey D80 Hardware Encrypted Flash Drive. Even if the drive is lost or stolen, your confidential information will remain safeguarded. High security with built-in AES 256-bit encryption prevents unauthorized users from accessing or even seeing files without first supplying the correct password. And after ten failed login attempts, your smart and self-defending IronKey drive automatically reformats itself.
The IronKey D80 Hardware Encrypted Flash Drive's combined encryption and password protection prevent storage of any content that is not encrypted. Simply plug in your device, launch the encryption application using your unique password, and rest assured that your files are protected. IronKey Hardware Encrypted Flash Drives keep your keys stored safely in the flash drive's own hardware. No matter where you go or what you do, your encryption keys never leave the device, so your sensitive data remains safe from external threats.
Protect your sensitive data
We live and work in a mobile world, and you need to make sure your data is always available no matter where you go. But you can't entrust your most sensitive and confidential information to just any flash drive. A poorly made drive won't stand up to heavy use or break-in attempts, and drives selected on price alone could leave your valuable information vulnerable to corruption, infection or theft. For an easy-to-use and reliable way to protect your most sensitive data, turn to the IronKey D80 Hardware Encrypted Flash Drive. Even if the drive is lost or stolen, your confidential information will remain safeguarded. -
Get the benefit of IronKey protection
High security with built-in AES 256-bit encryption prevents unauthorized users from accessing or even seeing files without first supplying the correct password. And after ten failed login attempts, your smart and self-defending IronKey drive automatically reformats itself. -
Confidently carry data anywhere
The IronKey D80 Hardware Encrypted Flash Drive's combined encryption and password protection prevent storage of any content that is not encrypted. Simply plug in your device, launch the encryption application using your unique password, and rest assured that your files are protected. -
Keep keys where they belong
IronKey Hardware Encrypted Flash Drives keep your keys stored safely in the flash drive's own hardware. No matter where you go or what you do, your encryption keys never leave the device, so your sensitive data remains safe from external threats. -
Built to stand up to what you dish out
IronKey D80 Hardware Encrypted Flash Drives undergo thousands of hours of rigorous read/write tests to help ensure users are getting a USB flash drive they can count on. And because nobody knows mobile like IronKey, this go-anywhere solution is encased in a sturdy chassis that's resistant to water and dust to help protect the drive and its contents from the elements. -
Designed with IronKey quality
IronKey D80 Hardware Encrypted Flash Drives offer mobile and/or security conscious users a true IronKey device - one built from longer-life, high-quality flash memory and components. Users will get read performance of up to 24 MB/second and write speeds of up to 10 MB/second.
- IronKey D80 Hardware Encrypted - USB flash drive - 4 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 4 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 4 GB
- 256-bit AES
- Read Rate
- Up to 15 MB/s
- Write Rate
- Up to 7 MB/s
- Interface Type
- USB 2.0
- Password protection, water resistant, dustproof
- Limited warranty - 5 years
- 75 mm
- 19 mm
- 9 mm
- 25 g
