Iron Key IronKey D80 4GB Hardware Encrypted USB Flash Drive
Quicklinx: BHP1WS00 Mfr#: MXJA0B004G5001
We live and work in a mobile world, and you need to make sure your data is always available no matter where you go. But you can't entrust your most sensitive and confidential information to just any flash drive. A poorly made drive won't stand up to heavy use or break-in attempts, and drives selected on price alone could leave your valuable information vulnerable to corruption, infection or theft. For an easy-to-use and reliable way to protect your most sensitive data, turn to the IronKey D80 Hardware Encrypted Flash Drive. Even if the drive is lost or stolen, your confidential information will remain safeguarded. High security with built-in AES 256-bit encryption prevents unauthorized users from accessing or even seeing files without first supplying the correct password. And after ten failed login attempts, your smart and self-defending IronKey drive automatically reformats itself.
The IronKey D80 Hardware Encrypted Flash Drive's combined encryption and password protection prevent storage of any content that is not encrypted. Simply plug in your device, launch the encryption application using your unique password, and rest assured that your files are protected. IronKey Hardware Encrypted Flash Drives keep your keys stored safely in the flash drive's own hardware. No matter where you go or what you do, your encryption keys never leave the device, so your sensitive data remains safe from external threats.
  • Protect your sensitive data
  • Get the benefit of IronKey protection
  • Confidently carry data anywhere
  • Keep keys where they belong
  • Built to stand up to what you dish out
    IronKey D80 Hardware Encrypted Flash Drives undergo thousands of hours of rigorous read/write tests to help ensure users are getting a USB flash drive they can count on. And because nobody knows mobile like IronKey, this go-anywhere solution is encased in a sturdy chassis that's resistant to water and dust to help protect the drive and its contents from the elements.
  • Designed with IronKey quality
    IronKey D80 Hardware Encrypted Flash Drives offer mobile and/or security conscious users a true IronKey device - one built from longer-life, high-quality flash memory and components. Users will get read performance of up to 24 MB/second and write speeds of up to 10 MB/second.
IronKey D80 Hardware Encrypted - USB flash drive - 4 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
4 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
5-year warranty
USB flash drive
Storage Capacity
4 GB
Hardware Encryption
256-bit AES
Read Rate
Up to 15 MB/s
Write Rate
Up to 7 MB/s
Interface Type
USB 2.0
Password protection, water resistant, dustproof
Limited warranty - 5 years
75 mm
19 mm
9 mm
25 g
