Iron Key Generic Ironkey 64GB D250 MLC Personal
Quicklinx: BD5LWS00 Mfr#: D2-D250-B64-2FIPS
When you're on the move, you want your personal information moving with you. With Imation Personal Flash Drives powered by IronKey, you can keep everything at your fingertips while leaving your worries at home.
Imation Personal Drives store all your private data, passwords and online identity in a single, easy-to-use USB flash drive. Everything stays locked down with military-grade, always-on hardware encryption. Unique features - a secure private web browser and password manager to name two - combine with the premium, high-performance flash memory to give you a secure platform for accessing your data and applications anywhere, anytime.
And it all stays intact with a waterproof, shock-resistant metal enclosure that's been hardened to stand up to thieves, competitors or just plain clumsiness. Lucky for you, this is one tough case.
IronKey Personal D250 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
64 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, AES-CBC, 2048-bit RSA, 256-bit SHA
MLC NAND Flash
Chinese (traditional), Chinese (simplified), English, German, French, Spanish, Japanese, Korean
Software Included
IronKey Control Panel
Microsoft Windows XP SP2 or later, Apple MacOS X 10.5 or later, Linux 2.6 or later, Microsoft Windows Vista / 7
5-year warranty
USB flash drive
Storage Capacity
64 GB
Hardware Encryption
Read Rate
Up to 29 MB/s
Write Rate
Up to 13 MB/s
Interface Type
USB 2.0
MLC NAND Flash
Encryption support, waterproof, tamper-proof, ruggedized, metal body, Cryptochip
Section 508, MIL-STD-810F
Software Included
Limited warranty - 5 years
75 mm
19 mm
9 mm
25 g
70 °C
