ioSafe Solo G3 4TB External Desktop Hard Drive 3.5" USB 3.0 with 1 year Data Recovery Service
Quicklinx: BX4LWS00 Mfr#: SK4TB-EU
With the ioSafe Solo G3 fireproof waterproof external hard drive you can rest knowing that your priceless memories - your family photos and home videos - are safe no matter the circumstance. Spend your time making memories, not worrying about how to protect them.
Don't leave yourself vulnerable for weeks or months trying to backup your entire computer to the cloud when you can have the ioSafe Solo G3 protecting your entire digital life in minutes. Complementing your existing online backup solution with an ioSafe Solo gives you the best of both worlds. Online provides offsite redundancy while the Solo G3 gives you the real-time backup, fast recovery speeds, privacy, and security life demands on a daily basis.
With the ioSafe Solo G3 you can easily and instantly protect and secure your personal financial information. Protect your private personal financial information from corruption, loss or identity theft by storing it locally and privately on your Solo.
  • Built for fire
    The Solo G3 protects your irreplaceable photos, documents, and work from fire. Rest easy knowing your data is safe up to 1550° for 30 minutes.
  • Floodproof, pipeproof, riverproof
    What if your family photos were submerged in 10 feet of water? Protect your valuable images and work with the Solo G3, which secures your data from basement floods for up to 3 days.
  • Peaceful on desktops
    No matter where you want your Solo G3 to live, its fan-free design means that it will remain quiet and unobtrusive.
  • Powerful, reliable backup
    For individuals, families, or small offices the Solo G3 is the perfect backup solution available. It's intuitive, fast, and has everything one needs to safeguard data.
ioSafe Solo G3 - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop)
4 TB
3.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Security lock slot (cable lock sold separately), water resistant, fire resistant, DataCast technology, FloSafe technology, HydroSafe technology
Power Source
Included AC adapter
12.7 cm x 27.9 cm x 18 cm
6.8 kg
Europe
1-year warranty
Bundled with
4 TB
3.5"
USB 3.0
Internal Drive Interface
Serial ATA
12.7 cm
27.9 cm
18 cm
6.8 kg
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B
Compatible Bay
3.5"
Power Source
Included AC adapter
Power adapter
AC 80 - 264 V (50/60 Hz)
Power Consumption
25 Watt (active)
Apple MacOS 8.6 or later, Microsoft Windows Vista / XP / 7
System Requirements Details
Windows XP/Vista/7 - Pentium II - 350 MHz , MacOS 8.6 or later - PowerPC G3
1 x USB 3.0 cable - external
UL, FCC, ASTM E-119
Europe
Limited warranty - 1 year
35 °C
20 - 80% (non-condensing)
