ioSafe Rugged Portable Solid State Drive 1TB USB 3.0 FIPS 140-2 with 3 years Data Recovery Service
Quicklinx: BX4DWS00 Mfr#: PAS1000UB3YR
The Go-Anywhere ioSafe Rugged Portable SSD hard drive has been designed to withstands the most extreme environments and will keep your data safe - wherever you take it.
The ioSafe Rugged Portable is the safest way to move data. Whether you need to protect data from drops during your commute or protect it from the most extreme environments on the planet, the Go-Anywhere Ultra Rugged Portable hard drive is up to the job.
Data has become increasingly mobile, but with that increased mobility comes increased risk. Delicate portable storage devices can easily be dropped during travel, stolen or exposed to adverse environmental conditions such as extreme temperatures, sand or moisture — all factors which can lead to data loss. The ioSafe Rugged Portable addresses each of these problems. It's tough enough to be used in arctic or desert environments, is shock and crush resistant, has anti-theft features and is backed by ioSafe's unique Data Recovery Service and No-Hassle Warranty. This means that if your ioSafe Rugged Portable stops working for any reason at all during the warranty period, we'll repair or replace the drive and recover the data from your old drive. ioSafe does more to protect your data than any other company.
  • Impact protection
    Tested to military standard MIL-STD-810G 516.5. Full suspension in all size axes of motion delivers drop protection up to 10'.
  • Immersion protection
    HydroSafe technology protects data during immersion up to 3 days in fresh water or saltwater to a depth of 30'. Unlike other products, the Rugged Portable remains waterproof when the USB cable is connected.
  • Crush protection
    Full Metal Jacket technology: CNC-machined from a billet of solid aluminum, the Rugged Portable is crush-resistant to 2,500 lbs.
  • Extreme environment protection
    EnviroSafe technology protects data from exposure to UV, blowing sand, blowing dust, rain, salt fog, icing or freezing rain for up to 24 hours per MIL-STD-810G 505.4, 506.4, 509.4 and 510.
  • Chemical protection
    ChemSafe technology protects data during periods of immersion in diesel fuel, oils, hydraulic fluids and aircraft fuels to a 12' depth for 1 hour per MIL-STD-810G 504.
  • Altitude protection
    AltiSafe technology enables operation at altitudes up to 30,000 feet per MIL-STD-810G 500.4.
  • SuperSpeed USB
    USB 3.0 connectivity delivers blazingly fast transfer speeds up to 5 Gb/s and backwards compatibility with USB 2.0.
ioSafe Rugged Portable - SSD - 1 TB - USB 3.0
Solid state drive - external (portable)
1 TB
Encryption Algorithm
FIPS 140-2
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Security lock slot (cable lock sold separately), Full Metal Jacket, Full Suspension Drive, HydroSafe, ChemSafe, EnviroSafe, AltiSafe
Power Source
USB bus
9.9 cm x 14.5 cm x 2.5 cm
1-year warranty
Bundled with
1 TB
FIPS 140-2
USB 3.0
9.9 cm
14.5 cm
2.5 cm
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Power supply
Software Included
TrueCrypt, Apple Time Machine, Genie Timeline Professional
Apple MacOS 8.6 or later, Microsoft Windows Vista / XP / 7
System Requirements Details
Pentium II - 350 MHz
1 x USB 3.0 cable - external , 1 x USB power splitter cable - external
MIL-STD 810G, AES-256, IP68, ISO/IEC 10118-3:2004
Limited warranty - 1 year
5 - 80% (non-condensing)
