ioSafe 214DISKLESS-EU 2 Bay Fireproof & Waterproof NAS RAID
Quicklinx: 9959WS00 Mfr#: 214DISKLESS-EU
  • Atom
The ioSafe 214 is a fireproof and waterproof, network connected, multi-drive NAS/RAID storage device for terabytes of your precious or business data. Designed to be the center of your private cloud, the ioSafe 214 is powered by a Synology DSM motherboard and operating system. It allows for fast access on your local network and remote access from nearly any device connected to the Internet - all secured and protected by you. The ioSafe 214 is designed and assembled by ioSafe in California - a data storage company with a vision to protect the world's photos, videos and business data in the vulnerable private cloud.
It's all about you. Your data. Your stuff. All of it.
The ioSafe 214 is the first disaster-proof private cloud device of it's kind. Like an aircraft black box for your data, the ioSafe 214 is designed to protect and secure terabytes of the most precious data on the planet - your data.
The Cloud Problem: Slow, Pricey and Insecure
If you have 20-30 GB to protect, the public cloud is an option. If you have terabytes to store, the traditional public cloud breaks down quickly.
Speed
Moving a terabyte online can take months. Three or four terabytes? Fuggedaboutit! Months to upload and months to download. It's faster to ship a hard drive across the country than to try to stream the data across the internet. The situation is only getting worse as data growth will continue to exceed bandwidth over the foreseeable future. It's the equivalent of pushing the Pacific Ocean through a garden hose.
Cost
To store a couple of terabytes on Amazon's S3 Storage over three years will cost over $8000. Granted Mozy, Carbonite or Backblaze combined with Dropbox can be a fantastic setup if (1) you don't have terabytes of data and (2) you don't have them on a NAS and (3) you don't care about disaster recovery for all your programs or OS in addition to your data.
Security
No one in the public cloud cares as much about your data as you do. Information gets hacked, deleted and compromised in the public cloud as the biggest databases represent the juiciest targets for hackers. Staying in control of how your local data is stored, accessed and managed is an excellent way to avoid risks of the public cloud.
Private Cloud
The private cloud (aka NAS with cloud-like applications: picture sharing, music streaming and file syncing) can help solve the speed and security issues associated with the public cloud. It's fast when you're local and accessible when you're remote. The security is set by you and only you: simply pull the plug out of the wall if you want to completely lock out all external access to your data. Once your data is out in the public cloud, you lose control over how or where your data is stored. It will invariably get replicated across the internet and can never be made completely secure again.
Disaster Recovery (DR) for the private cloud?
Streaming your data offsite for disaster protection is slow and is fraught with unknown risks regarding your service provider's policies and employees. Trying to replicate onsite and then physically move the data offsite for DR is a daily hassle and expense. You risk losing the data through human error, an unlocked car, disgruntled employee, etc. - bad things happen. Streaming or syncing terabytes online leads straight back to the public cloud's cost and bandwidth issues.
The ioSafe Solution...
ioSafe protects from natural disaster by wrapping its patented protection technology around vulnerable private cloud data - onsite. You get fast local access, redundant hard drives, security, nearly unlimited storage, cloud convenience, access to the data with virtually any device and onsite protection against natural disasters. It's a beautiful thing - digital Nirvana.
You can use our solution alone or in conjunction with your existing backup and DR practices if you have any already in place. Every situation is special and this technology is meant as a tool for you to use to reduce your vulnerability. There is simply no other single solution available with all the advantages of the ioSafe 214 for speed, flexibility, cost and disaster recovery.
  • It's all about you, your data. your stuff, all of it
    The ioSafe 214 is a disaster-proof private cloud device of it's kind. Like an aircraft black box for your data, the ioSafe 214 is designed to protect and secure terabytes of the most precious data on the planet - your data.
  • The Cloud problem - slow, pricey and insecure
ioSafe 214 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
8 TB
0 (installed) / 2 (max)
23 cm x 29.2 cm x 15 cm
12.7 kg ()
Europe
1 x Intel Atom 1.06 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
Card Reader
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
8
RAM
512 MB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
1-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
8 TB
23 cm
29.2 cm
15 cm
12.7 kg ()
Built-in Devices
Led panel
Europe
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP
Remote Management Protocol
Telnet, IPP, SSH
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), Syslog support, print server, video server, MySQL server, backup server, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, FTP server, Virtual Storage, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, WebDAV server, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
Security DVR
8
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), water-resistant, fire resistant
Security Slot Type
Kensington security slot
RoHS, ASTM E-119
External power adapter
18.48 Watt
Software Included
Drivers & Utilities, Synology Assistant, Synology Data Replicator
Limited warranty - 1 year
5 °C
35 °C
5 - 95%
Sound Emission
19.9 dBA
