ioSafe 1515+ NAS 30TB SATA 6Gb/s eSATA JBOD iSCSI with 5 years Data Recovery Service
Quicklinx: BX6WWS00 Mfr#: ND605-5
  • Atom
With its fire/water protection, superior performance, scalability, resilience, and comprehensive features, ioSafe NAS 1515+ is the ideal storage solution for your growing business. Featuring hardware encryption engine, and flawless software integration, the ioSafe 1515+ is a powerful, expandable 5-bay NAS server that delivers outstanding speed and accelerated data encryption. The 1515+ can help to simplify disaster recovery, business continuity, data management, sharing storage for storage and backup - with minimal setup and the freedom to expand capacity at any time.
  • Ultimate security and protection
    The ioSafe NAS 1515+ powered by Synology DSM is the ultimate in security because data remains local and is never exposed to the dangers on the traditional public cloud. All security details are 100% controlled by you - the person that cares the most about the data.
  • Fast encrypted data transmission with AES-NI
    Encrypting data is essential to a healthy security policy. Equipped with a dedicated hardware encryption engine, the ioSafe 1515+ is the ideal digital safe for sensitive data; files and folders are encrypted on the fly without any perceived performance loss.
  • Quad LAN ports for failover and Link Aggregation support
    Equipped with four Ethernet ports featuring failover and Link Aggregation support, ioSafe 1515+ ensures continual network uptime even if LAN connection malfunction occurs on one port, reducing the chance of service disruption and costly downtime. Link Aggregation improves connection speeds beyond the limits of a single network cable or port.
  • Robust scalability
    As your data storage needs grow, ioSafe 1515+ can be connected to dedicated expansion units for additional storage on the fly, growing capacity with minimal effort. With two expansion units connected through specially designed eSATA connectors.
  • iSCSI and virtualization ready
    With the iSCSI support in the Synology DSM platform, the 1515+ provides a seamless storage solution for virtualization servers, such as VMware, Hyper-V, and Citrix. It is the ideal alternative to SAN solution for businesses. Affordable and costeffective, iSCSI allows SMB users to consolidate storage into data center storage arrays while providing hosts with the illusion of locally-attached disks.
ioSafe 1515+ - NAS server - 30 TB
NAS server
Bundled Services
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
30 TB
5 (installed) / 5 (max)
24.8 cm x 23.3 cm x 15.7 cm
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
5 x 6 TB HydroSafe
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
5-year warranty
NAS server
Bundled Services
Host Connectivity
Gigabit Ethernet
30 TB
24.8 cm
23.3 cm
15.7 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
5 x 6 TB
HydroSafe
Network / Transport Protocol
PPTP, L2TP
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), print server, web server, Access Control List (ACL) support, e-mail server, VPN Server
Encryption Algorithm
AES
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x eSATA
Security lock slot (cable lock sold separately), water-resistant, fire resistant, built-in 2 cooling fans, Citrix Ready
Security Slot Type
Kensington security slot
Internal power supply
Software Included
Synology Assistant
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
