Intermec PM43 Monochrome Direct Thermal Label Printer
Quicklinx: 9TVPWS00 Mfr#: PM43A11000000202
£1,160.72 ex VAT
£1,392.86 inc VAT
PM43 mid-range industrial label printers are ready to perform, designed to maximize your uptime. Count on PM43 to deliver quick deployment and proven reliability. Ideal for a wide range of applications within the distribution center, warehouse and manufacturing environments.
  • Ready
    PM43 is ready to deliver maximum uptime. Reduce your total workforce training and device support needs with immediate notifications via the printer and the elimination of reconfiguration due to UI tampering.
  • Reliable
    As the 3rd generation of Intermec industrial printers, the rugged PM43 incorporates features that increase uptime and reduce maintenance costs. Strong all-metal construction is perfect for harsh industrial environments and the metal media door with innovative latch system ensures media is protected.
  • Perform
    PM43 is ready to perform. With the print speed of 12 ips, you'll gain a clear productivity advantage. PM43 helps to reduce labeling errors and increase process efficiencies. Printer stand-alone applications, developed through the embedded programming language, directly control other devices such as scanners, scales, keyboards and other peripherals helping you decrease infrastructure costs and complexity.
Honeywell PM43 - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
15.8 kg
Europe
Max Media Size
Roll (11.4 cm)
Min Media Size (Custom)
19.1 mm
Max Media Size (Custom)
114.3 mm
Print Speed
Up to 300 mm/sec - max speed
Max Resolution (B&W)
203 dpi
USB, LAN, serial
RAM Installed (Max)
128 MB SDRAM
Flash Memory Installed (Max)
128 MB
Language Simulation
ZPL, Intermec Printer Language (IPL), DSim (Datamax Interpreter), ZSim, Extensible Mark-up Language (XML), DPL
Barcodes
EAN/JAN, Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, HIBCC, LOGMARS, MicroPDF417, Codabar, Code 128, Code 11, Code 16K, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Plessey, AIAG, Standard 2 of 5, Grid Matrix Code
Media Type
Labels, linerless labels, fanfold paper, tag stock, tickets
Print server - Ethernet, Fast Ethernet
Printer Features
RFID ready, USB host
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
28.4 cm x 48.4 cm x 29.5 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Europe
Printer
Print Speed
Up to 300 mm/sec - max speed - 203 dpi
Built-in Devices
Touch screen
Wired
USB, LAN, serial
203 dpi
Language Simulation
Barcodes
Printer Features
RAM
RAM Installed (Max)
128 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
128 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
19.1 mm
114.3 mm
Media Sizes
Roll (1.9 - 11.4 cm)
Max Printing Width
108 mm
Media Weight
57.6 g/m² - 250 g/m²
Roll Maximum Outer Diameter
213 mm
Roll Core Diameter
76.2 mm, 38.1 mm
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
Print server
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, LPR/LPD, SMTP, FTP, BOOTP, DHCP
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP
1 x USB 2.0 - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x LAN - RJ-45 , 1 x USB - 4 pin USB Type A
Fixed media hanger
FCC Class A certified, UL, C-Tick, cUL, EN55022, CCC, RoHS
Power supply - internal
Frequency Required
50/60 Hz
300 Watt
Power Consumption Stand by / Sleep
9 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
20 - 80% (non-condensing)
28.4 cm
48.4 cm
29.5 cm
15.8 kg
