The EasyCoder PD41 is a dependable and versatile printer suitable for medium duty applications in manufacturing, transportation and warehousing environments. With all-metal chassis and covers, proven printing mechanics and powerful electronics, it provides the sturdiness and performance your business depends on.
The EasyCoder PD41 can print demanding crisp variable-data labels continuously at 150 mm/s (6 ips), thereby outperforming all other printers in its class. It takes industry-standard 200-mm (8-in) rolls of labels and 450 m (18 000 in) of ribbon, reducing downtime for loading media to a minimum. The printer accepts a wide range of paper types in different thicknesses, as well as both ink-in and ink-out ribbon.
In addition the EasyCoder PD41 offers many Smart Printing features normally found only in high-performance printers Multi-language capability and Intermec Ready-to-Work indicator are standard - all at an affordable and competitive price.
PrintSet, a PC-based setup tool, makes installation and setup of the EasyCoder PD41 intuitive and easy. The one-button interface makes the printer easy to operate and well protected against unintentional changes of the setup. An open and accessible design makes media loading quick and easy, and the printhead can easily be replaced without using any tools.
The ability to use any Intermec printer language and emulate other printer protocols makes the EasyCoder PD41 both fully compatible with other Intermec equipment and a cost-effective "drop-in" printer replacement in almost any non-Intermec firmware environment. Featuring full programmability (using Fingerprint), the EasyCoder PD41 can change with the application. There's no need to replace the printer when you upgrade your firmware environment - the printer will adapt.
The EasyCoder PD41 keeps your options open and protects your investment.
- Intermec EasyCoder PD41 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 13 kg
- Max Media Size
- Roll (11.8 cm)
- Max Media Size (Custom)
- 118 mm
- Print Speed
- Up to 150 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- Parallel, USB, LAN, serial
- RAM Installed (Max)
- 16 MB SDRAM
- Flash Memory Installed (Max)
- 8 MB
- Card Reader
- Language Simulation
- ZPL, Intermec Printer Language (IPL), EPL, DSim (Datamax Interpreter)
- Media Type
- Labels, continuous forms, fanfold paper, tag stock, tickets
- Networking
- Print server - Ethernet, Fast Ethernet
- 27.3 cm x 45.3 cm x 27 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
Printer
- Print Speed
- Up to 150 mm/sec - max speed - 203 dpi
- Connectivity Technology
- Wired
- Interface
- 203 dpi
RAM
- 16 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 8 MB
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Media Handling
- Media Type
- Max Media Size
- Roll (11.8 cm)
- 118 mm
- Media Sizes
- Roll (2.5 - 11.8 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 1520 mm
- Roll Maximum Outer Diameter
- 213 mm
- Roll Core Diameter
- 76 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.8 cm)
- Networking
- Print server
- Data Link Protocol
- TCP/IP, UDP/IP, ICMP/IP, LPR/LPD, SMTP, FTP, BOOTP, DHCP
- Remote Management Protocol
- SNMP, SNMP 3, HTTP
- Connections
- 1 x RS-232 , 1 x LAN - RJ-45 , 1 x USB , 1 x parallel
- UL, cUL, NOM, FCC
- Power Device
- Power supply - internal
- Frequency Required
- 45 - 65 Hz
- Software Included
- Drivers & Utilities, Intermec PrintSet
- 5 °C
- 40 °C
- 20 - 85%
- 27.3 cm
- 45.3 cm
- 27 cm
- 13 kg
