Intel X710-DA4 Quad port server adapter
Quicklinx: D5LLWS00 Mfr#: X710DA4FH
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, 10 Gigabit Ethernet
Form Factor: [N/A]
Compatibility: Unix, PC
Type: Network adapter
£364.78 ex VAT
£437.73 inc VAT
The X710-DA4 adapter delivers four ports of wire-speed 10GbE and is backwards compatible to 1GbE. Intel Ethernet 700 Series Network Adapters are the foundation for server connectivity, providing broad interoperability, critical performance optimizations, and increased agility for Telecommunications, Cloud, and Enterprise IT network solutions.
  • One adapter, one price
    With the Intel's adapters, iSCSI and FCoE support are included in the price of an adapter. There is no need to purchase multiple adapters or additional licensing for an X710 adapter. It's simple and easy. Everything you need to unify your networking is included in a single SKU.
  • Network virtualization
    Network virtualization is the next big trend in creating an agile data center. The family of X710 adapters are ready to help you take that next step.
  • Energy Efficient Ethernet (EEE)
    Reduces power consumption during periods of low data activity. Energy is used to maintain the physical layer transmitters in a "ready state" to transmit data on the wire. During periods of low data traffic, EEE sends a low-power-idle signal to put the transmitters into a "low power state" saving power and cost. When data needs to be sent, EEE sends a normal idle signal to wake up the transmit system before data is due to be sent so there is no degradation of performance.
Intel Ethernet Converged Network Adapter X710-DA4 - network adapter - PCIe 3.0 x8 - 10 Gigabit SFP+ x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 3.0 x8
Ports
10 Gigabit SFP+ x 4
16.7 cm x 11.1 cm
1GbE, 10GbE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMB, NFS
IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.1Qbg
Red Hat Linux 7.0, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Linux Kernel 2.6.32, FreeBSD 9, VMware ESXi 5.1, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, SuSE Linux Enterprise Server 11 SP3, Red Hat Enterprise Linux 6.5, VMware ESXi 5.5, FreeBSD 10, SuSE Linux Enterprise Server 12
Network adapter
Plug-in card
PCI Express 3.0 x8
Ports
10 Gigabit SFP+ x 4
Wired
Data Transfer Rate
10 Gbps
Remote Management Protocol
SNMP, RMON
Status Indicators
Port transmission speed, link/activity
Flow control, VLAN support, packet filtering, IPv6 support, TCP/IP offloading, QoS, VMDq, IPv4 support, teaming support, PXE support, LSO, GSO, RSS, SR-IOV, DCB, ALB, Energy Efficient Ethernet, TSO, checksum offload support, UDP/IP offloading, WDT, iSCSI boot
4 x 1Gb Ethernet/10Gb Ethernet - SFP+
FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS, KCC, Directive 2011/65/EU, MSA SFF-8431
16.7 cm
11.1 cm
Limited warranty - lifetime
55 °C
D5LL Intel Ethernet SFP+ Optics – SR In Stock £21.01
Protocol: 10 Gigabit Ethernet
Form Factor: [N/A]
Compatibility: Unix
Compatibility: PC
Brand: Intel
